Results 1 to 4 of 4
Thread: Sub A/V question
    Jan 2006
    Sub A/V question
    Ok I have a SB live USB card which works great btw and it has a sub channel which is also the center channel. The problem Im haveing and this might not be a huge problem seeing how my subs dont hit for **** is its split one red one white, red is sub white is centre. I bridged my amp so I have to have a set of A/Vs plugged into its input and two plugged into the output of the card but I only have room for one A or V. Does this make sense? Anyways the subs are not hitting for beans and when I say that I mean I can barely tell there on. Plz help thanks
    Jun 2005
    assuming you have no problems with your amp/subs. Try switching your rca's. you may have gotten your sub/center channel mixed up. How do you know that red is sub and white is center.
    Center channel shouldn't have "lows" on it. If you have you center rca pluged in to your amp, and you have your amp on low crossover. Then you will have very little sound coming from you sub. tmk
    Your sub should be mono you only need one rca for this. Is your amp capable running bridged?
    Is your amp set right, try turing up your gain. It's not a volume control.
    good luck.
    Jan 2006
    The gains are turned to roughly 75%. The only problem I might have is the LP and HP might be switched which I guess would make sense. I took the amp and the subs out of my car and plugged them into a buddies trunk which I also did and they pounded. So I know the equiptment works fine. Soo that leaves human error haha. And yes it has a bridged function on it for sure. Ahh im gonna die
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Are you sure that red is sub and white is center? Did you try switching those? I had the same problem with my setup initially. I found that in my software, subwoofer out was not enabled. After enabling it, the subs hit, but I could barely hear them....I then turned my gains down and they were back to normal.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. Replies: 2
    Last Post: 05-02-2006, 06:15 PM
  2. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  3. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 10:03 AM
  4. little question ive pondered..
    By John Crowe in forum Newbie
    Last Post: 04-06-2005, 05:09 AM
  5. DVD drive question
    By Pokey in forum Newbie
    Last Post: 05-11-2004, 05:26 PM
