Results 1 to 10 of 16
Thread: Distro block or no distro block?
    Mar 2005
    White Plains, NY
    Hey all. I have a 2 channel amp that I want to use to power my front two components. I was wondering if I'd have to use a distro block for this amp and my sub amp...or could I just run another power cable from my battery?
    The amp will most likely be up front somewhere and I think running a distro block would be kind of a pain in the ***.
    Any thoughts?
    Low Bitrate keen70's Avatar
    Dec 2005
    personal choice, make sure if u use distro then run a bigger cable from teh battery and 2 smaller from the other end.
    personnaly i use distro cause i just like the look
    Mar 2005
    NY
    Distro it. Its cleaner and looks nice and less cables running around. Just remeber to distro it back with the grounds
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Mar 2005
    White Plains, NY
    So, if I just went the non-distro way until I get some extra money to grab a block, I can ground that one wherever I want, correct?
    Like, I don't have to ground the amps at the same point, correct?
    Thanks! I think I'll start on this project today.
    _
    Mar 2004
    Little Elm, Texas
    you SHOULD ground the amps at the same point, you should ground everything at the same point if possible
    a distrobustion block is the right way to do this, some people could care less about doing things the right way though, so it's up to you. It makes things a lot cleaner, easier to wire and easier to troubleshoot.
    Jan Bennett
    Mar 2005
    NY
    distro it firs,t you'll save money on wiring. THink about it, do you want to run two 4 or 0 guagues from the hood to the trunk or just one and cheaply split it off into two short strands of 4 or 8 guage? Plus, distro blokcs, can allow room to grow, making them even more of a bargin. Ground to the same spot. I've heard grounding to the neg terminal on the battery is the best place, but still, just ground everything to the same spot or you'll be spending money on a ground loop isolator, among things.
    In short, just distro it to and distro it ground and you'll probably only have to check your wiring once.
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    _
    Mar 2004
    Little Elm, Texas
    re: grounding on the neg on the battery
    We ran a 1/0 run from the positive and negative terminals in my car, back to the rear passanger side pannel, behind it all. Have distribution for the positive and for the negative each. It means everything is grounded to one point and I KNOW it's a good ground too. Makes life SO much easier!
    Jan Bennett
    Mar 2005
    NY
    sweet, cause god knows if i did something stupid and fried a few hunrder in audio equipment and a fw thousand in computer, i'd be pretty ****ed
    See, i'm learning fast!
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Mar 2005
    White Plains, NY
    I'm only asking this because I really don't have the spare money to spend on distros. Also, this is just temporary. I am eventually going to distro the amps. I am not spending any money, I have all the cables I need. If I run two power cables with their own in-line fuses from the + battery terminal to the amps, then I just run two ground cables from each amp to the grounding spot I have, everything should work fine?
    I already have a nice sanded down spot in my trunk that my current amp uses for ground, it works fine. If I just add the other amp's ground to this, then everything should be fine, correct?
    I do appreciate the advice and suggestions thus far.
    - Jeremy
    _
    Mar 2004
    Little Elm, Texas
    yes, it should work
    however, i still recomend using a distrobution block
    Jan Bennett
  1. Distro block
    By Cheekz185 in forum General Hardware Discussion
    Last Post: 01-01-2006, 09:32 PM
  2. Aux Fuse Block
    By Dragonknell911 in forum General Hardware Discussion
    Last Post: 08-24-2005, 09:22 PM
  3. For Sale:: PS2 :: Distro block:: Musica RCA's...
    By infintyinf in forum Classified Archive
    Last Post: 06-21-2005, 09:19 PM
  4. Another Linux distro for car PC?
    By COST Linux in forum Linux
    Last Post: 06-14-2005, 03:24 PM
  5. Possible EPIA distro for Linux, Can we make one?
    By adamis in forum Software & Software Development
    Last Post: 02-23-2005, 06:50 PM
