Results 1 to 10 of 19
Thread: Amp question
    Low Bitrate jdisenberg's Avatar
    Dec 2005
    Kentucky
    Amp question
    I am familiar with hook up subs using the RCA cables. I got a amp to run my front speakers and it has a high input, and I am not familiar with this... how do I hook this up? It is like a five wire harness.
    Dec 2005
    Kentucky
    *bump*
    Low Bitrate keen70's Avatar
    Dec 2005
    Pics? BTW im from KY 2 lol
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    What are you talking about? "I am familiar with hook up subs" <--what does that mean?
    Try to use complete sentences and avoid typos, it's difficult to read and understand when you have to go over it several times.
    Also, You don't give any details at all in your description of the problem. Is this like a trivia game where we have to guess what you have in order to help you? Try describing the amp in detail and posting specs or pics if possible. Also, what are you trying to hook the amp up to (computer, soundcard, headunit)?
    Does your amp not take RCA's? What kind of an amp is it? Is it a car amp? What is a high input?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Dec 2005
    Albany, GA
    it should tell you want those wires are. You come off the your head unit speaker outputs into the high level inputes on the amp. It must be an old amp if it doesn't have RCA
    Trying is the first step toward failure
    Dec 2005
    Kentucky
    It has RCA too, but under those it says low input, would that be ok? And the instructions do say what the wires are but I am not using an HU, I am using a mac min.
    Dec 2005
    take pics of the amp and stuff man...post it and we will be able 2 help..if u dont have camera then u can try the "low thing"
    Dec 2005
    Kentucky
    Yeah, sorry about the typos. I am not familiar with hooking up amps...
    By the way, it is a memphis amp.
    Aug 2005
    Anaheim Hills, Ca
    If your not familiar with hooking up amps, than I would recommend having it installed professionally. Installation alone shouldn't cost that much, but it could save you a lot of problems down the line. You could mess up your amp, alternator, and/or car battery if you don't know what your doing...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Dec 2005
    Kentucky
    I am going to have the power installed by the pro. But I am building the box and running my cable, actually installation will not be done by me, but I want to do as much as I can.... And it doesn' hurt to learn what this is.
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 03:19 PM
  2. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  3. PAC Audio Aux input amp pop question
    By knubile in forum Car Audio
    Last Post: 05-03-2005, 08:28 AM
  4. Amplifier/sub question...
    By technopsych in forum Car Audio
    Last Post: 05-22-2004, 06:28 PM
  5. seperate amp, no head unit question
    By saletel in forum General Hardware Discussion
    Last Post: 12-16-2001, 03:18 PM
