Results 1 to 6 of 6
Thread: simple question i can't find an answer 2!!(did search!!)
    Jerusalem
    hi i just installed my 4 channel amp
    i got an onboard sound drive, how can i connect the sound from my pc to the amp. i got one of those normal headphone plugs that goes into a white and red plug. but this gives power to only 1 channel!! (i put the red in channel 1 and white in channel 2 inputs) i have plugged all 4 speakers into the amp and tested them to make sure they are the actual speakers.
    i found a few 4 channel sound cards like this one http://www.ebuyer.com/customer/produ...duct_uid=48179
    but it still has the same output plug!! (headphone type)
    can any1 help me please
    thanks
    93 MAZDA MX6 KLZE (sold :( )
    2005 STI :)
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    normal headphone 3.5 plug has 3 segments you need one with 5 (never seen a 5 segment to phono but they might exist) or use a y spliter to increase your 2 channel outputs
    Mar 2005
    NY
    hehe, about 5 years back, i bought an adapter for my hugh noise cancelling studio headphones and only one ear worked. I got ****ed and swapped out everything, including the headphones. To my embarrassment, alter on, i figured out the problem. The moral of the story: make sure you didn't buy mono .
    Buy the sound card. It shoudl provide better sound anyways and if you have a 4 channel amp, its the best way to utilise all that the amp can give. Ofcourse, you can bridge the amp (use only two channels and it will power as a two channel amp) and run you speakers in parallel or serial (one side of your car on one output, the other on the other). That takes alot of effort and rewiring. Just get the soundcard.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    Quote Originally Posted by Genesisfactor
    im sure you meant series?
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Mar 2005
    NY
    its 2AM...i can't be held responsible for typos! yes, i meant series.
    And look what you went and did, now i can't even correct myself cause everyone now knows i messed up. Well, i AM lazy...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Jerusalem
    thanks for the help
    2005 STI :)
  1. I know nuuuuthing............
    By dzrtram in forum Newbie
    Last Post: 06-14-2005, 04:38 PM
  2. OPUS simple question
    By Frankino in forum Power Supplies
    Last Post: 06-08-2005, 04:56 PM
  3. Another PSOne Mod question. Looked but no answer!
    By Learic in forum LCD/Display
    Last Post: 06-27-2004, 02:02 AM
  4. Question for Developers - Help find WMP bug workaround
    By GingerPrince in forum Software & Software Development
    Last Post: 01-14-2004, 02:52 AM
