Do it at your own risk. Even if using high level input on the amplifier, it is said not to use output of another amplifier. Can only use the signal that comes from head-unit. Well... if gain is adjusted properly, this signal will cause no harm for your amplifier, but as I said, all at your own risk.
Maybe you can use the signal before the stock amplifier?
LinkBack URL
About LinkBacks
