yes its ok
Hey!
I am 99.99% sure this can be done safely, but I want to see what you guys think. I am looking for a center channel speaker for my car, which will come off of a 5th speaker output on my DSP amplifier. I am planning on only sending vocals through the center channel, so was thinking of hooking up a tweeter. However, since they come in pairs, I was thinking of hooking both of them up to the one speaker output. If I hook them up in parallel, they'll both get the same voltage, but the impedance on the amplifier will double. This is OK, isn't it? Just wanted to make sure. Thanks!
-Ben
yes its ok
Bass is like cocain... ITS ADDICTIVE
couple days till i have bump in da trunk
_/---|____
|_@___@_| <<===My lowrider
we had this huge discussion several times on MP3cars, where surround sound is one of those topics. There's no point in adding a center channel. Your'e not on center. the best thing you can do is ad a speaker directly infront of you, but that woudl jack up your imagine badly. Stick to 4 speakers. if you so terribly want a center speakers, alpine has one ofr a a decent rpice i think. But i just wouldnt' do it. at all. wave phsyics says not to.
Disclaimer aside, make sure you have a 1ohm to 2 ohm tweeter set. If not, you'll damage your amp. Read its rating. I it can take higher impednace, then sure, go right ahead and make it happen. Just stay within limits and you'll do fine.
I still wouldnt' reccomend it though
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
A tweeter has very little impedence. You can add a tweeter onto a 4 ohm speaker and it wont usually stress the amplifier to a 2 ohm load.
Doesnt the tweeter and speakers have a passive crossover? Use that and problem solved.
