Results 1 to 10 of 14
Thread: Will an optical link fix my ground loop?
    Sep 2005
    All -
    I am going to try to approach this alternator whine problem I have in a new way. As many of you know, I've determned at least that it is not my amplifier. However, no amount of grounding, rewiring, or other troubleshooting has fixed my issue which appears to be as simple as an electrical differential existing which is causing electricity to flow from my PC to my amp via the RCAs, causing an obnoxious alternator whine. So, my USB sound card has a TOSLINK optical digital output. If I buy another USB sound card (eg. Audigy NX) which has an optical in (or some sort of other external digital sound processor/DAC) then that should eliminate the ground loop, because it won't traverse the optical link, right?
    I know this may seem like a sledgehamer approach but I assure you, I have spent far, far too long trying to isolate this noise from entering my amp, so whatever works now.
    Mark
    Variable Bitrate numbers's Avatar
    May 2005
    An optic cable is indeed the perfect solution for a ground loop, but I don't quite understand your proposed configuration. You need a converter at the amp to feed the optical signal into the analog input of the amp.
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    You need to elaborate a little more on how you are planning on doing this.
    What is your current setup? (carputer, amps, HU, etc....) I know how annoying tracking down a whine can be but there may just be something that you haven't tried yet or a trick or work around that someone may come up with.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Sep 2005
    I would use the optical SPDIF out on my PC soundcard to the SPDIF IN on the Audigy 2 NX external soundcard. The amp would still be connected to the Audigy 2 NX via 3 Monster 3.5mm stereo to RCA cables.
    Anyone giving me odds on this working or not?
    May 2005
    Yup. 0% chance of it working. You still have the same loop through the amp and sound card. The only way it will work is if you run optical out to a digital - analog converter, then rca as short as possible from the converter to the amp.
    Elsewhere
    You want to run optical from one sound card to another?
    What is that going to accomplish, really?
    You still have the analog output to your car audio system, so you've resolved nothing at all.
    Now, if you were to get a DSP that will accept the optical link from the soundcard, that would resolve your issue. But that hardware ain't cheap.
    How about the Wiki?
    Sep 2005
    I don't entirely understand these last two comments, though they are along the lines of things I thought I might hear. I've determined previously that it is not USB sound card, it is somewhere at the actual computer or upstream. How would the loop cross the optical link? The only way I anticipated a loop still exisiting is possibly via the power supply to the external USB sound card or via its USB connector, but I was planing on snipping the power wires within the USB cable if that was a problem or not connecting it at all. Here is a simple diagram, with dashed lines - optical link:
    PC (SPDIF out)-----------(SPDIF IN)AUDIGY NX-+RCA-+Amp
    Pwr Pwr Pwr
    I__________________________I_______Gnd__________I
    I would think the optical link would break the loop, as it has no capability to carry the electromagnetical signal. ANyway, sorry it is a crap drawing, and I am probably wrong, I just didn't see the difference between using a second soundcard "backwards" and a DSP.
    If the DSP is the route I have to go, can you recommend a model? I know some have popped up on this board, but it seems results are mixed. Thanks for the help guys, at least I am close - one way or the other. I can't take the frustration anymore.
    May 2005
    You're giving mixed information. If the problem is at the computer or upstream, then it isn't a ground loop. If it's a ground loop, then it is almost certainly the analog cable between the sound card and amp. Either way, your proposed solution won't do any good.
    Sep 2005
    Quote Originally Posted by numbers
    If I plug a MP3 player into the sound card I do not get the whine. That seems to me to rule out the analog cable or the soundcard as the loop. Thus I am trying to sever it at the next point, the computer to the card. I haven't read anything that enlightens me as to why a DSP will work and my solution won't. That said, again, anyone recommend a DSP?
    Feb 2006
    I am using the Radio Shack Catalog # 270-054 Noise Filter and it works well. If you have ground loop or alternator noise this filter removes all of it without harming the sound in any way!
  1. The quest for no noise
    By mp31500 in forum General Hardware Discussion
    Last Post: 04-02-2007, 11:12 PM
  2. audio noise and ground loop isolator
    By jdogg1583 in forum Car Audio
    Last Post: 07-03-2005, 11:42 AM
  3. NEW Wireless Optical Laser Link . Free Space Infrared.
    By Jammer in forum Wireless Communications
    Last Post: 01-19-2005, 03:13 AM
  4. Learn and fix ground loop noise
    By 14.4vTech in forum Car Audio
    Last Post: 07-03-2004, 09:55 PM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
