ok...first of all, ur kenwood amp dosent put out wut it says*srry man)
2nd, DONT GO BANDPASS
3rd, get a 12 inch ascendat audio arsenal from www.ascendantaudio.com and build a 2.5 cubic foot ported box tuned to 28Hz
getting amp KENWOOD KAC-9152D 1800w Class-D Mono Amp Amplifier---looking for sub to go into 1994 Accord-- any suggestions?
specs:
Max Power: 1800 wattslooking for reasonable budget... right now i have a band pass box for 2 - 12's--
RMS 500 watts ( 4 Ohms, Less than 1% THD+N)
Rms 900 watts (2 Ohms, Less than 1% THD+N)
RMS 900 watts (1 Ohm, 100Hz, 1% THD at 14.4V)
Power MOS-FET Switching Power Supply
Dual Mono Drive
1 Ohm Stable
Variable Low-Pass Filter
Remote Bass Boost Control
Infrasonic Filter
Line Output
Speaker Level Input
Gold Plated Power & Speaker Terminal
Bass is like cocain... ITS ADDICTIVE
couple days till i have bump in da trunk
_/---|____
|_@___@_| <<===My lowrider
is there somewhere i can get measurments?? what kind of wood?Originally Posted by keen70
will this amp have enough watts to make the arsenal sound right??? you say wont get what specs specify, what does this amp put out??Originally Posted by keen70
for the wood go with 3/4 inch MDF
deminsions are 22x15x18
go 2 www.partsexpress.com and get a 4 inch diameter port and cut it down to 14.35 inches in length
_/---|____
ok, that amp will put out 70-80 percent of what it says, so wire ya arsenal down to 2 ohms and hope for the best
_/---|____
any suggestions which 4 inch port to get??? where in the box should the port be placed??
http://www.bcae1.com/spboxnew2.htm
says with Fs: 27Hz and Qes .59 =EBP 45.76 (best with sealed enclosure)
i know but its also great ported.
Any 4 inch diameter port will do, as long as its the right length
_/---|____
but which one is over 14inches??? sorry for my ignorance, new to car audio-- my field of knowledge is in recording/engineering..
