Results 1 to 10 of 20
Thread: No head-unit, need optical out from PC to RCAs - Suggestions?
    Sep 2005
    Hey all,
    I'd like to use a DSP or Digial Analog Converter to break my ground loop problem, because I can't take it anymore. However, I'd prefer not to spend $300, either. So, I came across an old thread that said only the CY-AC300 and ADD51T would work for folks like me that don't have a head unit are simply planning to use the SPDIF optical out on my Audigy 2 NX to drive my standard 6-channel amplifier's RCAs (I know some may require an optical/coax SPDIF converter).
    However, I hear rumors that there are others that will work as well, like maybe the Alpine PXA-510. Is this true? Are there others? My concerns are that (a) I don't want to have to buy a head-unit (b) I want to control the volume using my carpc (in other words I don't want to have to have another set of dials I have to use to adjust volume) and (c) I want to be able to get sound out of my fronts and rears, even when I am listening to non-surround material (read: I don't want my MP3s to just play out of the front speakers).
    Some posts on this site have led me to ask about the items listed above. Please let me know if you can help me out. I will be very grateful to be done with this whine. Thanks!!!!
    Mark
    Sep 2005
    A couple more possibilities? DDTS-100, DAV-2100?
    Sep 2005
    Leaning toward the PXA-h510 or ADD51T. If anyone has any other less expensive options (I use an inverter, so I think most home solutions would work as well), please let me know. I'd like to pull the trigger on this by tomorrow. Thanks.
    Falls Church, VA
    What if the audigy has the ground loop? I havent spent much time reading your posts but it seems like you need to fix the original problem instead of the band aid.
    My guess is you are going to go through all this work and have the same problem
    Sep 2005
    The Audigy isn't the problem, as I've determined and conveyed in a few previous thread. However, even if the Audigy had the loop, it will not not pass the electrical current across the RCAs.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    why not a ground loop isolator?
    Sep 2005
    Quote Originally Posted by binary.h4x
    Tried the Radio Shack model - no workie for me...
    Oct 2004
    NY
    the 510 is a great option on a budget.... there is also a much less known alpine piece called a h400 I belive..... it's just a x-over with optical input & rca outs.... also would work.... if you can find one of these it should be really cheap as most don't even know what to do with them.... there scarce though... 510 should be easy enough to find
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    It's the h600, and you're right.......it's nothing more than a phase crossover.
    Oct 2004
    NY
    wasn't there an h400 also... I think I even have one or 2 somewhere...
  1. Can a car-computer replace a stereo head unit?
    By CA 3000GT in forum General Hardware Discussion
    Last Post: 11-13-2006, 10:24 PM
  2. Review: Kenwood KDC-W6527 Head Unit
    By chewiee in forum The Review Palace
    Last Post: 06-22-2004, 03:14 PM
  3. using head unit to control/display from pc...
    By vincerules in forum General Hardware Discussion
    Last Post: 01-23-2003, 06:18 AM
  4. Replies: 0
    Last Post: 01-06-2003, 02:35 AM
  5. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 04:57 PM
