Results 1 to 5 of 5
Thread: Building ported box-need help...
    Feb 2006
    was advised to get rid of the band pass and build ported.... can someone guide me the best way to accomplish this... is it as simple as building box 22X15X18 then putting 4 inch port in it???? thanks in advance
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    You need to know a lot more than that...like what sub you have for example along with its specifications and recommended box sizes...I believe there are programs that will allow you to input your brand of subwoofer and help you design the box.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    It would be best to just build a box according to manufacturers reccommendations. So check the papers that came with your subwoofer, and you should find reccommended box enclosures.
    If you wanted to create your own customized box for your personal preference (which you have to be careful not to damage your subwoofer), then do a google search for WinISD, or Bass Box Pro, cant really think of any other programs. I myself use WinISD (get the beta verison). However, I really reccommend just saving your time and going with the reccommended enclosures. Don't worry, they know how most people like their bass
    They usually give you a range too (such as 2.5 to 3 cubic feet of air space, and a 10 inch long, 4 inch diameter port). In the given example, the tuneing would vary from roughly 32hz to 29hz, which if you plot the difference in a program such as WinISD, you will see their is little difference, which would go unnoticed.
    None of my examples account for volume taken up by the subwoofer or the port, but as you can see, their really is a bit of a fudge factor without a noticeable difference. And if they give you actual box dimensions, then just figure out the volume, and you can make the dimensions any size you want, just as long as you mantain the same volume. Of course, with slot ports, this could complicate things.
    Simple enough, right?
    It really is simple, dont worry!
    Matt
    Feb 2006
    i was looking at the arsenal 12 www.ascendantaudio.com but they are all sold out... any suggestions for this amp??
    KENWOOD KAC-9152D 1800w Class-D Mono Amp Amplifier---looking for sub to go into 1994 Accord-- any suggestions?
    specs:
    Max Power: 1800 watts
    RMS 500 watts ( 4 Ohms, Less than 1% THD+N)
    Rms 900 watts (2 Ohms, Less than 1% THD+N)
    RMS 900 watts (1 Ohm, 100Hz, 1% THD at 14.4V)
    Power MOS-FET Switching Power Supply
    Dual Mono Drive
    1 Ohm Stable
    Variable Low-Pass Filter
    Remote Bass Boost Control
    Infrasonic Filter
    Line Output
    Speaker Level Input
    Gold Plated Power & Speaker Terminal
    looking for reasonable budget... right now i have a band pass box for 2 - 12's--
    Feb 2006
    need model of sub, specs for box and info on tube (size and where to place) thanks again for ya'll advice....
  1. building a speaker box
    By samael in forum Off Topic
    Last Post: 05-15-2009, 04:46 PM
  2. Box building software
    By 92stealthRT in forum Car Audio
    Last Post: 02-09-2006, 08:25 AM
  3. 2 12in RF Punch Z's with ported R/T box
    By Redmachine in forum Classified Archive
    Last Post: 07-19-2004, 08:24 PM
  4. Building my first mp3 car box but......
    By stevens in forum Power Supplies
    Last Post: 05-27-2002, 06:18 AM
  5. Building a box for Sub
    By Dima in forum Off Topic
    Last Post: 08-10-2001, 11:44 AM
