looking at the audiobaun AW1206T 12"??? enough watts to push one?
i was looking at the arsenal 12 www.ascendantaudio.com but they are all sold out... any suggestions for this amp??
KENWOOD KAC-9152D 1800w Class-D Mono Amp Amplifier---looking for sub to go into 1994 Accord-- any suggestions?
specs:
Max Power: 1800 watts
RMS 500 watts ( 4 Ohms, Less than 1% THD+N)
Rms 900 watts (2 Ohms, Less than 1% THD+N)
RMS 900 watts (1 Ohm, 100Hz, 1% THD at 14.4V)
Power MOS-FET Switching Power Supply
Dual Mono Drive
1 Ohm Stable
Variable Low-Pass Filter
Remote Bass Boost Control
Infrasonic Filter
Line Output
Speaker Level Input
Gold Plated Power & Speaker Terminal
was going to spend bout $150 on a sub and build ported box, looking for suggestions and spec to build one... thanks in advance....
Originally Posted by gameboy
link?? thnks
this amp even have enough watts to push???
Power Acoustik MOFO-12 12" 2400 Watt
or Power Acoustik FUBR-12 ?? less watts good for amp?? or go for other 2400???
i hear the fubr's are good. but seriously tho, you wouldn't have gone wrong the type r's. that is one badass woofer. they can get pretty loud and sound amazing. i've heard nothing but good thing's about those. the L7's can get hella loud ported but the sq isn't that great. there's mixed opinions on PA. btw you double-posted. see the other thread.
Originally Posted by dkguitarist
ended up coppin the type r--- havnt hooked any of it up yet-- building enclosure....
audiobahn sucks!!!!!!! so does most of PA stuff too, i would have waited for the AA Arsenals but Alpine Type Rs rnt bad. btw your going to be overpowering that type r by about 400 rms so you might wanna take it easy on the volume...
Video of My Sub- (playing Mike Jones- Guess Whos Back)
RE SX12 at 35hz
Resonant Engineering 12
also if your dimming which you might with the 900rms your gonna wanna upgrade your Alternator to a High Output Alternator. www.exessiveamperage.com << talk to nathan and he will hook up nicely.
DO NOT get a cap or extra batteries while on your stock Alt. it just puts more strain on it and your battery. read these if you have time:
http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.wickedcases.com/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
http://www.optimabatteries.com/
-greeney
RE SX12 at 35hz
