Results 1 to 8 of 8
Thread: using a 1 ohm amp to power 2 ohm subs?!
    Newbie atlantamane's Avatar
    Feb 2006
    Atlanta
    would this be possible to do. the amp is 4000 watt mono and is 1 ohm mono. would using 2 ohm subs bring down the amp to somewhere around 2000 watts? is there a possibility to run say... six subwoofers that are all 2 ohm and rated around 2000 watts by one amp? if not, how many amps should i consider getting if possible.
    Falls Church, VA
    You could run 50 subs off that amplifier if you like by mixing parallel and series connection intermixed.
    if you wanted to run 6 speakers off of that amp, where each is 2 ohms, then do the following:
    Pair up subs so you have 2 groups of 3 speakers. Wire each group in parallel, plus to plus, minus to minus. Now you have 2 "speakers", each with a .6667 impedence. Now wire those in series and you have a 1.2 ohm load. Divide total power by six and each speaker is "seeing" about that much power.
    If you need more power then run 3 amps.
    My question for you is if this is a carpc forum, why does your first post have nothing to do with carpcs at all? There are hundreds of car audio forums out there that cater to this type of intellect.
    Mar 2005
    NY
    my question is why do you need 6-2000W subs? Who in the back seat are you trying to kill?
    ***edit***wrote out this whole thing and will goes and i think edits his with the same calcuation...unless i totally missed that huge paragraph on calcuations
    anyways, good luck with your car pc.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Falls Church, VA
    mwahahaha, no edit on my post!
    Mar 2005
    NY
    hehe, i miss having short term memory!
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Feb 2006
    bad idea
    its a bad idea to put speakers in paralell. this will cause decreased bandwidth and give you waveform distortion on either end of the spectrum they were designed. But if you do, it will work and will not damage the amp as long as you have the impedence matched correctly. The reason why you get distortion when "piggy backing speakers" is due to the stray capacitances in the voice coils. Adding so speakers the one output with change the Q of the circuit that the amp is supposed to work with. This in turn gives you poorer audio quality than you would have had with a correct speaker. To correct this problem you can get a proper cross over which will allow you the 2 ohm speaker or two 2 ohm speakers, this will match the amp to the load.
    Falls Church, VA
    Series or paralel?
    and if you look at the capacitance, the alterations to frequency response fall outside of the woofers designated bandwidth anyways.
    Oct 2008
    amp 2000 watt rms at 1 ohm and three 2ohm subs
    i need some help from anybody that know alot about car audio..i have a hifonics hercules amp and 3 hifonics 2 ohm subs. i want to wire them somewhere around a 1 ohm load because my amp puts out 2000 watts rms at 1 ohm. if someone can tell me how to achieve that ,that would be great. thanks...
  1. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  2. Some advice on amp for subs
    By LowLux in forum Car Audio
    Last Post: 02-24-2006, 03:30 AM
  3. Amp Popping on power down
    By tjp12100 in forum Newbie
    Last Post: 12-26-2005, 11:22 AM
  4. psu to power amp and speakers?
    By qaz in forum Car Audio
    Last Post: 05-31-2005, 10:27 PM
  5. VW Golf: Power cable from Battery to the Amp...
    By SamDude in forum Car Audio
    Last Post: 10-03-2004, 03:16 PM
