When you say 'power strip', what do you mean? Is that a DC distribution block or an AC powerstrip?
Are all of your components grounded to the same point?
What kind of amplifier do you have? Is the PC case grounded properly?
The specs for the add51t don't say anything about an optical output; Only optical input. I'll assume that you're connecting this to the amp via regular RCA cables.
Still too many questions though. I would take out the PC and see if you still have noise with just the ADD51T and amplifier turned on. Work backwards from there.
LinkBack URL
About LinkBacks
