it doesnt matter, less ohms, the louder/more wattage they are. all subs can be wired in different configurations from 8 ohm to 1/2 ohm. It really depends on the wattage/ohm rating of your amp.
which is better and why?? thanks for ya'lls oppinion..
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
good to know, thanks... new to caraudio learning more daily...
If you are new to car audio, then you may want to go here
http://www.bcae1.com/
-Matt
kudos on that call - that site is a good read for anyone
Originally Posted by kirbycope
It depends on the amplifier powering the subs and the number of subs that you have. If you have a mono amp that is one ohm stable....your going to watn to take advantage of that fact and configure your subs so that you can wire them down to 1 ohm. 2 dual 4 ohm subs, for example, can be wired together down to 1 ohm, while one 2 ohm sub can be wired down to one ohm. You should basically pick out the subs you want and then get the amp to match.
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
ive got a kenwood that says @ 1ohm is 900 watt... also copped the alpine type R supposed to only 500watt rms--- should i wire this @ 1 ohm???
NO
if your kenowwood has 900W rms and the same as another guy's on the forum, you can make it 4 ohms at 550W, which is find for the subs.
Here's the thing. The impedance (ohms) depends on what you plan to do. If you get a hgih powered sub and want to run multiple subs, you can do it wiht either 2 2Ohms subs in parrallel (4ohms total) or 2 4 ohm subs in series (2 ohms). That's where impedance matters. Your amp, however, can push more power with less impedance, so you can choose subs based on that.
***same thing 3on said, but i hope it makes it a bit clearer. If you wnat, make a list of subs you want and the amp you have and i'll mix and match***
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Surely 2x 4ohm subs in series would be an 8ohm load?Originally Posted by Genesisfactor
damn it i reversed them! Thanks DavC. Do the OPPOSITE of what i said!![]()
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
