Results 1 to 5 of 5
Thread: Will my HU accept a CD changer?
    Oct 2004
    I want to have a P.I.E. Aux In gizmo hooked up to my 2006 Chevy Trailblazer with the base radio. This will let me hook up an XM radio I already own. Fine print on the PIE gizmo says head unit must be capable of accepting a cd changer, if not the PIE won't work. How can I tell if the HU will accept a cd changer? Dealer's service guys are totally clueless.
    HU does have the 12 pin connector on the back. Has RDS too.
    THANKS.
    Elsewhere
    It's your vehicle, so you've got the resources to make this determination.
    Usually, an OEM's base-model headunit doesn't include changer controls.
    And unless someone has an '06 GM vehicle with the same model headunit, nobody's going to understand what the 12-pin connector is for.
    How about the Wiki?
    Dec 2005
    Albany, GA
    The easiest way to tell if it has changer controls is to look on the radio for a CD button, trusting that you don't have a cd player in the front. Peripheral makes numerous adapters to make this work if you can.
    Trying is the first step toward failure
    Mar 2006
    It could work if. . . .
    I've had the same converstions with many incompetant dealers and technicians about this one. I have a 2005 Trailblazer with a stock single disc cd player. If you'll notice at the bottom left of the radio there should be a button that says something like CD/AUX. If you have this, and there is a header for a changer on the rear of the radio (several pins wide), then you should be golden. The warning that PIE gives has to do with the upgraded radio that already has XM, ONStar, etc which you and I don't seem to have. I hope this helped.
    Jun 2004
    Rochester
    If you have the 9 pin connector that looks this one, your chances are probably pretty good.
  1. M-Bus CD changer adapter for car pc integration
    By jbors in forum Input Devices
    Last Post: 09-20-2010, 02:30 PM
  2. P.I.E. Sony Dual CD Changer Interface & Auxiliary Input
    By Chita79 in forum Classified Archive
    Last Post: 09-17-2005, 04:22 PM
  3. How to connect to CD Changer
    By hyundaiguy in forum Car Audio
    Last Post: 07-27-2005, 07:18 PM
  4. CD Changer Cutting Out
    By ClubFed11 in forum General MP3Car Discussion
    Last Post: 03-15-2005, 05:43 PM
  5. FOR SALE - ICE - Clarion Top End Mini Disc & CD changer
    By Paul_GPvR in forum Classified Archive
    Last Post: 01-21-2005, 06:28 AM
