Page 19 of 40 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 397
Thread: Why not PC speakers?
  1. #181
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    Come back to this post about a year later, and see what you think.
  2. #182
    Jun 2005
    Burnsville, MN
    Quote Originally Posted by checksum View Post
    I haven't started the project yet, hopefully very soon, had to priotize other stuff in my life, but I am still considering the idea.
    Just listen to yourself...
    First off, I am not competing with anyone here for me to go hide or be ashamed. If it does not perform as I expect, I will just remove it and go with the regular speakers and the amp, nothing to be embarrassed about.
    And call me stupid or ignorant, that will not make any difference for me. As I beleive it will work great until I prove myself wrong.
    Ok.. it cant be a money thing.. you already have the speakers.. i believe you have the inverter.. what are you waiting for!!
    7 months later.. no response..
    i guess that means we are all right, doesnt it...
    The bitterness of poor quality remains long after the sweetness of low price is forgotten
  3. #183
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by zryder View Post
    well, we probably are right about not using pc-speakers.... But that doesn't have to be the reason he hasn't started the project yet.... I have stuff laying around for over a year and still haven't started to put it in my ride.... just because TIME's an issue...
    anywho..... is this discussion still going on? DAMN.... pc-speakers won't work, periot!
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  4. #184
    _
    Mar 2004
    Little Elm, Texas
    just leave it alone guys....no need to drag it back up from 7 months ago...
    Jan Bennett
  5. #185
    Jun 2005
    Jupiter Florida and New York
    Awwww why not dredge it up? Lest we be barraged by some other squid that wants to try this. Heck it should be made a sticky!
    This subject is soooo 30 years ago. But back then the quality of car audio stuff was for crap. Remember 8 track car players?
    Man at the time we were sticking all sorts of home gear in cars trying to get better sound. Going through all the nightmares of figuring out how to make it work. We really envied the VAN guys that had all that room to stick home speakers in there. Remember the Custom Van craze of the 70's and early 80's?
    Finally the aftermarket car audio industry started catching on, and now the car manufacturers are catching up with quite decent OEM audio and car computing products.
    The need to even go the home brewed car PC route is becoming less and less attractive.
    Soon the hot thing will be hacking the OEM car pc installations to utilize the already installed LCD screens and controls so as not to have to go through the fabrication and integration nightmares.
    I still have not figured out why the aftermarket hasw not embraced digital out from the head unit to the amps solution. Heck SPDIF digital out from players and amps has been mainstream in home audio for a while now. It eliminates most of the noise prone RCA wiring, and leaves analog only to the speakers.
    Anyway heck if you dont care how your stuff sounds, yea you can just toss any old amplified computer speaker in your car. Better yet just do it like we did back in the 70's. Go to wallmart and get a boom box that runs on batteries and toss it into the passenger seat hook up your Ipod to the line in jacks and Boom away.
    At 157.2 DB no one will hear you scream
  6. #186
    _
    Mar 2004
    Little Elm, Texas
    digital doesn't have the quality that analog does. The sound is much more processed and not as lifelike as it is in analog. Thus the reason in most very high end home and car set-ups, you won't find optical connections, or digital for that matter.
    Jan Bennett
  7. #187
    Jun 2005
    Um too processed? So you still like the SQ of analog cassette tapes? Vinyl records? Just what form of recording do you think exists on a cd? Sorry but the second you pop a CD into a player you have gone digital. Might as well carry it all the way to the amps.
    Or you can always rent a limo hire the rolling stones and have em play your music live
    Bumping at 157.2 DB no one can hear you scream!
  8. #188
    _
    Mar 2004
    Little Elm, Texas
    Optical connections are not known for recreating absolutely accurate sound. The cables cause reflections which creates issues. Even up until recently I believed that optical was the way to go, but upon further research, it's not ideal and is the reason that most high end set-ups aren't using it any more.
    I was not referring to the media, but rather the transmission.
    Jan Bennett
  9. #189
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by RedGTiVR6 View Post
    Time to get better transmission then!
    Personally I think it's crap they fall back to analog just because a cheap technology doesn't suffice.
    They should get some error-correction in (2-way communication) and digital transmission can be bit-perfect from one end to another.
    A good example is a USB-DAC. USB is far more reliable than spdif, and it works great.
    Also, in very high-end setups, the errors from optical outweigh the problems with analog, because a lot of money goes to overcoming the problems of analog. For any budget slightly lower than that, optical will be the better option...
  10. #190
    Variable Bitrate breaker021's Avatar
    Apr 2005
    Midtown Manhattan
    http://forum.sounddomain.com/forum/u...=5;t=011261;p= - someone did it and digs it. ;]
    - sh00k
    Duct tape and a Bandana for the win, b!shes!!!
    My Setup:http://www.mp3car.com/vbulletin/show-off-your-project/73500-06-scion-xb-tablet-in-the-box.html
    Cost so far: Less than a grand ;]
    _________________
    Economy/Commuter cars + Computers = many entertained miles
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. Where Shud I Place My Pc
    By xdjxklusivex in forum Fabrication
    Last Post: 01-13-2005, 08:45 AM
  4. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 09:00 PM
