Page 22 of 40 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 397
Thread: Why not PC speakers?
  1. #211
    May 2006
    Perth, Australia
    Quote Originally Posted by checksum View Post
    I doubt, I will ever take these speakers past 1/2 the volume. I mean just sitting down surrounded by 5 speakers that are about 4 feet away from you, and the bass pumping was just too much. I don't know how many WATTS that was, but it was just too damn loud, and the sound wasn't distorted at all. And these speakers are only 550WATTS.
    Uhm... what?
    I'm with durwood and 2k1Toaster on this one. Road noise and wind will kill this most likely. And the durability issue.
    Road noise will likely kill your mid-range.
    There's always the possibility that you haven't had a fair deal of experience with properly tuned sound systems. Personally I find too many people buying themselves a Logitech/Creative speaker package and thinking it's state of the art. Yea, they're fancy, but they're not as "audiophilic" as many would like to think.
    Too many times I've had someone tell me how great they are, and then watched their speakers distort at 50-75%+ volume. I can't say my computer's sound setup (compenent hi-fi system) doesn't, but that's because I'm yet to have it reach 50% volume, as the SPL is too high with 2x one metre full range towers in a 4x4 metre room.
    The reason your speakers seemed so powerful is because you're using a system that's designed for a much larger environment. Bringing them into an environment as small as a car cabin is increasing the SPL a great deal, and thus the volume.
    Most of all, the issue is road/wind noise and durability.
    I'm not saying that PC speakers in a car won't work, I'm just saying that it would be of very questionable quality.
    - Of course it sounds clear, if memory serves, each of your satellites have two tweeters, and with five speakers, that's a lot of treble.
    I'm just seriously doubting the endurance of the audio when we start talking intefering sounds, ie. your wind and road noise.
    Then again, maybe I'm just not convinced because you seem to think your speakers are out to get you.
    "I only went half way with the volume, and I was about to go death"
    "I was scared to go all the way, because I thought I might go death"
    I am however eager to see the results after a road test.
    Be sure to keep us posted,
  2. #212
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    sound is all subjective, i'm glad you're happy with them. You saved a grip load of cash :-)
    Quote Originally Posted by Un_discovered View Post
    when i had my old system with 75wpc it was very very loud in the driveway. when i was on the highway I'd have to max out the computer's volume (there was no distortion even at this point with my old setup) and it still would be drown out with engine and road noise.
    the biggest potential problem i see; besides headroom, with that has been touched upon already. the sat. speakers are probably x-overed very high and that's going to bring the soundstage back behind your head.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #213
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    any word on how it turned out, Checksum? would love to find out...
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
  4. #214
    May 2006
    Perth, Australia
    Uh-oh, looks like he's gonna disappear for a year again.
  5. #215
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    I will let you know as soon as I run the test. I had to RMA my motherboard, so it will be another week or so...
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
  6. #216
    Apr 2007
    Florida
    that sucks dude...hopefully you didnt have to send it back to MSI...cause i waited 2 months to get mine back and without them telling me what they fixed on it, they sent it back saying it worked (on a page in the box they put the mobo in)...when i put everything back in, it still didnt work...turns out it was my HDD which developed a short somehow which prevented me from turning on the computer. the mobo had a bad component as well...so it wasnt just the HDD...i hope you have beter luck with yours
    edit: they did fix one part on the mobo, but never told me what...
    Subwoofer: removed
  7. #217
    May 2006
    Calgary, Alberta
    This took 15 pages? It's common sense.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  8. #218
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I could have told everyone this works. I mean a speaker is a speaker, give it a powered signal and it will produce sound. New PC speaker do sound hella good! I think the debate here is not weather or not it will work but how to retrofit PC speakers into your car speaker locations. This can be done with good fabricating. My main concern with this setup is the same problem with running a PC power supply from an inverter. Its dirty, very inefficient, and bulky. What you are failing to see is that PC speakers have a built in amp so you are not eliminating the amp. You are powering a 110 volt amp with a 12 volt inverted source. If you can get a clean signal from that setup than I say go for it. Realistically though the cost of fabricating custom mounts for the PC speakers would probably offset the cost of just buying real mobile audio equipment. Hooking up a mobile system to a carPC is actually very easy. I spent about the same as you on my 2 amps and sub and I'm pretty sure it can out perform my high end desktop PC speakers.
    Your nissan looks like it had a PC explosion lol
  9. #219
    Oct 2006
    Bear, DE, USA
    Quote Originally Posted by blk02si View Post
    Agreed. If the guy was getting anywhere near 500 watts in practice after inversion, he'd probably be looking at a new alternator. The speakers he's using are efficient, but of questionable accuracy in the midrange, and I could probably...check that, I know I could do better, SQ wise, in a car, with a ported JL 10w0 and two (2) Pioneer components in factory locations. I know what the logitech's sound like, and I had my old Ford Focus sounding better than my in-house Logi's with a similar setup (4 chan Pioneer amp, Boston FX series speakers up front, JL w0 in rear (sealed...but if he wanted to approximate the sound of the Logi's, then ported)....and at similar cost, practically drop-in fabrication, no inversion power loss/noise.
    Yes, PC speakers will "work" in a car. But in the end, you can get similar or better sound at similar cost with something that doesn't require fabricating of the extent this does. The logitechs are made to sound boomy in the low end and have clear highs, precisely because they are engineered to be used primarily for movies and games.
    I don't want to sound preachy, and I commend the OP for having the gumption to try it out, and I'm far from an expert...but I do know from experience what it would take to fab something that would make that set of Logi satellites not look ghetto in a vehicle I cared about. Can it be done? Sure! But very much pain for very little gain, unless you're one of those that's happy with Logitech satellite enclosures bolted onto your dash. I'd be deeply ashamed of such a setup if I didn't fab the satellites and sub in...and my wife would have a fit. But that's just me.
    I have too much time and too little aggravation in my life, so I built a carPC. ;)
  10. #220
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    newbs...
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. Where Shud I Place My Pc
    By xdjxklusivex in forum Fabrication
    Last Post: 01-13-2005, 08:45 AM
  4. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 09:00 PM
