Page 1 of 40 1234567891011 ... LastLast
Results 1 to 10 of 397
Thread: Why not PC speakers?
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Why not use PC speakers?
    Those of you who have a CARPC, why not use decent computer speakers? Most of them are 5:1.
    Their sound is great, very clear and most of them come with a sub. They are also very cheap nowadays.
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    Variable Bitrate numbers's Avatar
    May 2005
    I suppose because the speakers which can be mounted properly in your car work well and are better suited for car audio to begin with.
    Feb 2006
    Columbia/MD
    But you save a lot of money, you don't have to worry about buying any amps.
    If you can build a carpc, i am sure you can take apart your computer speakers and make them fit somehow in there, and nowadays they are small. I know I can.
    Just 2 amps 1 sub and 4 decent speakers can easily run you for around 500.00 or more, with 200.00 you can have a nice set of 5:1.
    Am I missing something here???
    Just imagine putting these in your car, it would sound as good as any car speakers setup out there
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by checksum
    For the same reason that people don't take apart good house stereo speakers and install them in thier cars, or vice versa.
    Michael
    Feb 2006
    Columbia/MD
    well, that is more of a space issue there, house stereo are too big. But computer speakers are as small as car speakers, just take them out of their enclosure and you have a set of nice speakers.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    That is not 100 percent correct.
    First of all, the housing is designed to hold a speaker, and is designed ina certain way to make the speaker sound good. Changing the housing by installing the speakers in the door, where there is no speace behind the speaker, will change how the speaker sounds. Additionally, what might sound good and lous in your quiet house (well, there is no road or engine noise) may not be able to overcome the inherent noise of your car. Also, the speakers in your house may not be as resistant to RFI as speakers made for the high RFI environment of your car. And of course, the position of speakers in relation to your head has a dramatic impact on the sound quality. In your home, you can place the speakers almost anywhere, to achieve the perfect setup. In a car, the speaker location is less then ideal. Car speakers take this into account, while your PC speakers do not.
    Does this mean that THERE IS NO WAY IT WILL WORK IN YOUR CAR, nope. Is it likely it will work in your car, nope.
    Try it, and let us know.
    Michael
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    To get it to look nice it would be a big job to fabricate housings and to "build in" those computer speakers into a car....by the time you put effort into that it'd be easier just to put in a regular car audio amp and replace the speakers in the stock locations.
    Those computer speakers you listed above are pretty good but that sub (and any of the subs I've seen with computer speaker systems) aren't going to give you nearly the response of a typical car sub w/ dedicated amp, plus you'd put in a lot of effort to integrate the speakers into your car, make it look good, hide the wires, and deal with the electronics (volume controls, etc..) on those systems.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    1) Most PC speaker systems run off A/C and would not work very well in a car. You could use an inverter but amplifiers designed for an A/C powersupply rarely sound good hooked up to 12v.
    2) Most PC satelite speakers are engineered around their enclosures. Some may use ported and/or bandpass designs to get the most out of a small driver. Taking them out of the enclosure will only make them sound worse. Leaving them in the enclosure means you might run into depth problems (ie you can't roll down your window if they are mounted in the door)
    3) The satelite speakers have absolutely no bass and rarely match up with the subwoofer's audio. If you throw the subwoofer in the trunk there will be a huge gap in sound between 400Hz and 80Hz.
    4) The satelite speakers (as well as most home audio speakers) are designed to be listened to on-axis, or facing directly towards you. Car audio speakers are designed for optimum performance at off-axis mounting positions such as your door. Car audio speakers are also designed for optimum performance in an infinite-baffle or free-air enclosure (i.e your door).
    5) PC subwoofers are designed to produce optimal bass in a large area such as your office whereas car audio subwoofers are desgined to produce a smooth bass curve in a small area such as your car. They are also designed to handle more power and greater excursion. It is very difficult to get a response below 35-40Hz in your home so most PC systems don't even try to go below that. It is very possible to get down to 20Hz in a car and car audio subwoofers take advangage of that.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Because then cars 4 lanes over on the freeway wouldn't be able to feel the bass or hear the highs....duh...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    RIGHT
  1. Speakers setup and placement
    By kingtut in forum General Hardware Discussion
    Last Post: 08-13-2007, 03:37 PM
  2. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  3. Where Shud I Place My Pc
    By xdjxklusivex in forum Fabrication
    Last Post: 01-13-2005, 08:45 AM
  4. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 09:00 PM
