Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Buying a new amp, need advice
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    I've used thye button but the pickings are slim and new technology comes out all the time so last months post may not be the best to judge anything by.
    I have a Mazda Protege 5 with the stock speakers, head unit, and amp. I'm replacing the head unit with a carputer and a touch screen lcd. I'm looking for a good quality amp (doesn't have to be top of the line) that will work with the stock speakers. I'm sure I need atleast a 4 channel amp or more. Down the road after the system is working I may very well upgrade the speakers but as it is now they work fine so an amp that can handle speaker upgrades would be a plus too.
    Any suggestions? I'm new to the car audio askpect so take it easy on me please.
    Thanks in advance
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by Splash-X
    Thanks in advance
    I would suggest looking in the classified section of a car audio forum and look for good quality 4 channel amps. It is very easy to get a used high quality amp that works perfectly for really cheap. I would suggest looking for a JL 300/4 because it is very versatile in terms of application. It can handle varying input ohmage (1.5 - 4) and that is a plus when dealing with stock speakers. Most of the time, stock speakers can be 3 ohm or some other non-standard number. Later on, when you upgrade to aftermarket speakers, the amp would definitely help them to stand out...it's a clean amp.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Mar 2005
    NY
    hmmm....my firend has an audiovoxx 4 channel for sale. They're supposednly AMAZING amps. I was goign to pick it up if mine failed, but you seem to need it. Anywyas, do an amp upgrade , but do the gain adjustment carefully. If you still have distortion at medium sound levels, you'll need new speakers that can handle your amp.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Mar 2006
    Palm Harbor, FL
    Quote Originally Posted by Genesisfactor
    English please?
    I'm a computer repair tech and now I know what my clients think when I try to explain things to them.
    How much is the amp and does it include the manual?
    Aug 2005
    You need to find out what ohm your speakers are. The higher the number in ohms, the quieter the speaker is going to be, but the less stressful it will be on your amp. Most aftermarket car audio equipment is designed for 4 ohms as the standard. If your stock system is 8ohm, the system is going to sound quiet(er) even with a replacement amp than if the speakers have a lower ohm rating. It would be recommended to replace your factory speakers at the same time you install the amp, especially since its generally such an easy thing to do, and you could buy four new speakers for about $60. To summarize, think of using the stock speakers as using PC2700 RAM instead of the PC3200 that your mobo supports. Thats not the best analogy, but its not the worst either. Also, if you have more than four speakers in the car, you're going to run into more issues if you try and integrate them all.
    Once you install the amp, turn the gains all the way counter clockwise to start with. Next, turn the volume up to roughly 3/4, and begin turning up the gain until you hear any form of distortion. After that, back off the gain a little for safety. Do not turn the radio up past 3/4 volume once you have done this to make sure you don't damage anything. This goes for either stock OR aftermarket speakers.
    As for amps, just do your homework before you buy. Watts of power are watts of power, but some brands advertise more realistic numbers and put out clearer sound than others.
    In the works...
    Dell GX240 SFF
    P4 1.8GHz, 256 RAM, 160GB HDD
    8" Lilliput (fab work completed - F-150)
    My worklog
    Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
    Mar 2006
    Palm Harbor, FL
    Smokin, Thanks for the info.
    The car has 6 speakers, one in each door (4) and then two on the front doors by the mirror, small speakers.
    I'm down for replacing the speakers. Lets say I go to crutchfield.com or similar, I just need the amp, the 4 speakers (or should I replace the small ones as well?) , wiring kit for the amp?
    Are Sony or Infinite amps good?
    Feb 2006
    Anchorage
    http://www.msprotege.com/forum/showthread.php?t=69147
    This could give you a little background knowledge for car audio, esp since you drive a P5... if you have a model specific question, the search button on www.protege5.com (same site as above, just easier for me to remember since I drive a P5 as well)
    Infinity and Sony will power your speakers, however I don't think Sony is making the quality of car audio products that they should be capable of...
    Inifinity is excellent midrange car audio, can't say anything bad about it at all...
    Aug 2005
    Ugh, looks like your car uses 6x8's from the factory. Since I'm sure you don't want to put all that much time and effort into putting in a traditional 6.5" (you would have to make a piece to fit that speaker in the hole), Here's a couple alternatives.
    More expensive, but best sounding option:
    Polk db5250 5.25" component set - This has your small speakers as well as the main speakers for your doors, but they're a little more work to install. You'll have to find somewhere to hide the crossovers, and you'll have an adapter plate that you'll also need to install, which is easy.
    Polk db570 speakers - These will fit your factory rear location.
    Phoenix Gold Octane R 8.0.4 amplifier - This should power it all just fine, and the value per dollar is hard to beat.
    Cheaper alternative is to Search E-bay for some new 5x7 or 6x8 speakers. Pioneer, Kicker, MA Audio, MB Quart, Alpine, JL Audio, and Kenwood are all decent name brands. Some are a little better than others, but you generally get what you pay for. If you had 5.25" or 6.5" speakers, it would've been cheaper.
    In the works...
    Dell GX240 SFF
    My worklog
    Constant Bitrate fooshizn1x's Avatar
    May 2005
    714 - Socal baby!
    I would look all over for the different information about amps, there is definately a line between low end amps and good sound quality amps. For instance, a quick look at ebay shows 1000 watt amps such as "boss audio" and "legacy" and "pyramid" which are all under $100 bux. then you can look at other amps that cost a few hundred dollars but show a lower wattage such as JL audio, orion, rockford fosgate, PPi, etc. First I think you should look at your budget of what you have to spend on the total upgrade and try it with the stock speakers before you spend money on replacing them. I dont have a "carputer" installed yet so I cant talk from that aspect, but I run my truck w/ aftermarket headunit and stock speakers, 2 12's and a large amp for the 12's, and its pretty loud and pretty clear.. to a point.. then it distorts.. when you look into purchasing speakers, have your amp either in mind, or purchased, and get speakers that require the amount of power that of what the amp puts out. so if your amp puts out 60 watts rms per channel, get speakers that will handle 60 or 80 watts rms.. not 300... you dont utilize the speaker to its full potential and in my opinion it doesnt sound as good. there are lots of good used apms to be had at decent prices, some of which are seen advertised here, ebay, local paper, car audio forums.. just post some questions if your unsure, we'll steer you in the right direction... and while crutchfield is a good retailer.. their prices are crazy.. I'd shop locally if you want it brand new.. or ebay/paper/forums for used..
    Jan 2004
    Florida
    Quote Originally Posted by SMOKINV8
    That's not true, if you have speakers that take 50 watts at 8 ohms then you will need an amp that puts out 50 watts at 8 ohms. And will actually sound better than the same speakers at 4 ohms with 50 watts. You sacrifice some speaker control when you drop the ohms, but you get a more power out of your amp.
  1. Replies: 20
    Last Post: 03-19-2006, 05:01 AM
  2. PC to AMP - AMP to Speakers connection
    By craigt in forum Car Audio
    Last Post: 09-23-2005, 09:36 AM
  3. Replies: 2
    Last Post: 08-22-2005, 05:37 PM
  4. Powering Carputer and amp ...
    By TxMazda3 in forum Newbie
    Last Post: 06-03-2005, 04:12 AM
  5. Having problem with AMP, need HELP!!
    By ryuandwings in forum Car Audio
    Last Post: 05-01-2004, 08:31 PM
