Results 1 to 8 of 8
Thread: bizzare amp problem
    Mar 2006
    bizzare amp problem
    i have just added an amp and a subwoofer box to my existing system but the amp only comes on when im actually changing the subwoofer settings on my head unit and it only lasts for about 2-3 seconds. the head unit is a kenwood kdc-w6031 and the amp is a 4*100 watt jbl da3504, the subbox is 2*12s with peak power of 500 watts.
    i would really apreciate any help you guys can give me with this problem, cheers. steve
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    My guess is that this is a configuration issue with the head unit. All I can say is read the instructions. Look for something related to enabling/disabling the subwoofer pre-outs.
    Mar 2006
    i have read the manual but that didnt tell me anything.
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    "Switchable, adjustable rear subwoofer output." from http://www.justkenwood.co.uk/stock01/kdcw6031.asp. Does it have more than one set of outputs for a sub?
    What did you connect the amp's remote turn on wire to?
    Check your equalizer, Loudness control and bass adjustment. Make sure they are not too high
    ps: wtf is this doing in the faq section?
    REBUILDING!!
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    sounds like the remote turn on is hooked up incorrectly...
    Nov 2005
    UK
    Quote Originally Posted by Dragonknell911
    and does this really have anything at all to do with carputers?
    anyway, most likely it is your remote turn on lead that has been connected to the wrong wire as mentioned above.
    Aug 2004
    Clearly that does'nt matter.
    Oh and everyone runs amps and speakers with their carpc's, so yes it does.
    REBUILDING!!
    _
    Mar 2004
    Little Elm, Texas
    hrmm - are ya going to respond vangore?
    can't help much more if we don't hear back from ya!
    Jan Bennett
  1. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  2. power to amp problem
    By djXternal in forum Car Audio
    Last Post: 06-01-2005, 10:39 PM
  3. Replies: 4
    Last Post: 05-17-2005, 05:17 AM
  4. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  5. Having problems running audio from my Shuttle to my amp
    By 0din in forum General Hardware Discussion
    Last Post: 06-19-2003, 02:41 AM
