Results 1 to 5 of 5
Thread: Attention to Wiring Gurus!
    Mar 2006
    Hey if you're reading this I thank you already since I need some advice...
    Here's the deal, I had a set of JBL P953 6x9s as my rear speakers until one of them blew....I wasn't able to find just one of the same speaker so I ended up with a Alpine SPR-694A TYPE R to replace the one that blew. Now my question is, can I hook this Alpine speaker up to the (JBL brand) in line Crossover that came with the JBL P953 speakers or do I need a new crossover for it? Since the Alpine 6x9 I got has 2 separate connections one for the tweeter and one for the woofer, I don't know how to hook it up to the amp without using the crossover that came with the JBL's so I need a hand....?
    Thanks again for reading!!
    May 2005
    hey i am an mobile installer for years, really the right way to solve ur problem would be to get another jbl speaker, or another alpine with the matching xover set u can do it now but every speaker company has different xover points jbl might cross thier tweeter higher or lower than alpine so dont expect even sound from ur rear fill , and the alpine has 2 sets of terminals because its bi-ampable , just make sure high section of xover goes to tweeter and low to woofer
    Feb 2006
    You cannot use the JBL crossovers with your Alpines. The impedence of the speakers change the crossover points.
    _
    Mar 2004
    Little Elm, Texas
    chances are the alpines have an onboard crossover.
    If you hook it up to the JBL crossover, you will essentially be passing the signal through two crossovers.
    this could cause all kinds of problems. Impedence issues, crossover points, etc. Not worth the time and hastle. buy another set of the JBLs, that way you have an extra for the next time you blow one...
    Jan Bennett
    Newbie 12voltking's Avatar
    Feb 2006
    as a further note...if you blow a speaker...replace BOTH. Chances are that if one is dead then the other is damaged.
  1. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  2. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  3. ATTENTION Car Mechanic Gurus
    By SPyder_Flex97 in forum Off Topic
    Last Post: 11-07-2002, 01:33 PM
  4. Attention LCD Gurus
    By Rob in forum LCD/Display
    Last Post: 06-24-2002, 09:47 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
