No you can't. The 529T is load limited.
I use that same module as a windows module 10 for the pass 10 years.
The 529T may have different intenal than the one I have/had.
Hey guys I just got my Viper 790XV installed yesterday and it has a sunroof module (529T), my question is, is there a way of setting how far back it takes the sunroof? Because right now it takes it about 1/4" farther back then it normally should and make a slight noise once it reaches that point
Debating on installing a carpc in my Jeep.....
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
alright but there is a way to set at what resistance the module responds to to shut down the motor correct?
That is something I don't know.
Alright, yea im not sure about it either... I hope there is a way of doing it though
well the 529t dont have a easy way to chage the resistance.the 530t has a way to adjust the resistance thru some deep sw's.i know this module is design for power windows up and down,you can even use it to close and open your sunroof.......
about the noise be carefull this cut be a signal that the 529t is still powering the motor even if the sunroof is completely close.
BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
RRTube ==> [View/Download Youtube Videos]
WifiMan ==> [Wifi Manager]
RRec ==> [Audio Capture]
If You Want To Be Given Everything, Give Everything Up ...
Bird York -- In The Deep --
