Results 1 to 10 of 12
Thread: Sound deadening...
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Sound deadening...
    Hi,
    I'm wondering if anyone has used barrier matting (lead-impregnated rubber matting!) in a car before, and if so how well it works. A friend did say that I can't put it anywhere near the exhaust, or possibly even the floor above it. I could put it on the first layer of mats (already weigh some 8kg each), but below the top dressing mat, or is it better when in contact with the vibrating metal itself? Definitely some :
    On the transmission tunnel (2 layers)
    the whole rear floor (80"x36" or thereabouts)
    on the rear wheel wells
    and under the driver and passenger mats and on bulkheading.
    He also mentioned some kinda spray-foam? which is this?
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    I've never used it, but it should work. Remember, all you are trying to do is to stop rattles by increasing mass. A good spray foam that is used for sealing off compartments is called great stuff. I don't know how good it is at sound deadining though.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Apr 2005
    Ireland
    but it can't be put in the doors, lol the window won't work
    Sep 2003
    Tampa, Florida
    I've used some stuff I found at my local home improvement store called "Quick Fix" gutter repair tape:
    I think there is similar stuff called "peel n' seal". Both products are made for roof repair I believe. Here are a few pics of my car interior with the deadener installed:
    WORKLOG
    Webpage
    Apr 2005
    Ireland
    How well does it work? much road noise?
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    I used Peel'n'seal. Its great accually, proably the best money I have spent on my Jeep. I put down two good layers and three over the wheel wells.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
    Feb 2006
    Quote Originally Posted by Snootch
    Not just that, rubber type products absorb vibration. Steel is much more massive than rubber but if you bang two pieces of steel together they will chime or resonate; two pieces of rubber banged together won't.
    Apr 2005
    Ireland
    presumably it's quite good (the foam) as it contains loads of air, which can trap sound. Right, I was belting downthe motorway at 90+mph and I wondered why i could barely hear myself think - I'd left the 2" thick rubber deadening mats at home for the Roadworthiness test (which it passed BTW )
    Low Bitrate tasteItheIvalue's Avatar
    Nov 2005
    Connecicut; United States
    I used the stuff in my trunk, works very good. killed all rattle from the subwoofer. Also now if u knock on the trunk, it sounds solid... knock on the doors its tingy. i will do the doors next.
    Mar 2005
    Plano, TX
    Snootch, how much did that stuff cost you and how much do they give you?
    Peel 'n Seal recently must have gone up in price. I used to pay $10 ish, then $12.47, now its $13.68.
    NINe.2X, NINe.2
  1. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 10:04 AM
  2. Sound Card discussion, 4.1, sound quality, need help
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-19-2005, 09:47 AM
  3. Sound Quality with External USB Soundcard
    By nirvanades in forum General Hardware Discussion
    Last Post: 08-12-2004, 05:34 PM
  4. alright, sound distortion from over boosting.
    By ares in forum General Hardware Discussion
    Last Post: 03-14-2004, 12:04 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 09:01 AM
