Results 11 to 20 of 23
Thread: CarPC -> Amp (Headunit-less)
  1. #11
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    I think you could do this without too much trouble, actually. You need to find a harness that goes from the square amp harness to RCA. I have seen them out there, but I don't know where to get them. If you can't find one, you can solder RCA ends onto a harness like the Metra 70-5511. Then just run RCA cables back to your carputer, use an RCA-mini adapter and your set. Be sure to turn the factory amp on by sending 12V to the blue/white wire in the gray aftermarket power harness. I don't know how it would sound, but it would work. Good luck.
  2. #12
    Registered User cliffloehr's Avatar
    May 2006
    Decatur, AL
    Check out http://www.stangnet.com/Tech-Article...Head-Unit.html
    This should be helpful!
  3. #13
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Maybe I'm missing something, basically you want to go right into the stock amp correct?
    See if metra has a "Factory Integration Harness", that's what I did.
  4. #14
    Apr 2005
    Boston, MA
    I think this is it. $5-$15 bucks.
    Metra #70-1770
    On Froogle
    Might want to double check at http://www.metraonline.com. They're super helpful.
    This might be of interest as well.
    http://probefaq.org/audio/audio.html#Book_11
  5. #15
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    the metra one is no good. get the scosche adapter from crutchfield.com
  6. #16
    Low Bitrate schpanky's Avatar
    Jul 2005
    Holy crap, thanks for the awesome responses, guys! I knew there was a way! I already ordered a ton of different components, but I guess they're going in my porsche
    1995 Ford Mustang Convertible
    DSATX | Shuttle XPC SN41G2Bv2 | 619GL-70NP | CF 1.6 (which is still unusable in the car!)
  7. #17
    May 2006
    Decatur, AL
    It looks like your Shuttle PC has the same sound output as my VIA M10000 mini-itx motherboard so we should be going through the same learning curve. I ordered the METRA 70-5519 Harness Friday (after finding that article on stangnet) and I'm fabricating the CarPC case for my 2001 Mustang right now. The dash is all ripped apart and I feel you pain! I sure hope we don't have to go buy new amps! The MACH460 amps seem to have plenty of punch. I really like what Specimen did on 94 Mustang GT and plan on following his design.
  8. #18
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    I know you've been given alot of mach 460 info already, but take a look at what I have on my personal site (link in sig). You might find something useful there. I have schematics/diagrams/pics. I actually took my front amp out and added an aftermarket headunit while maintaining, if not improving, the sound. I'm still utilizing the rear amps. peace...
  9. #19
    Jun 2006
    www.crutchfield.com has a huge amount of info on this stuff.
    Although I would like to have an aftermarket amp and speakers, for now I am going to use the stock Mach 460 amp until I get some more cash.
  10. #20
    Apr 2005
    Boston, MA
    Quote Originally Posted by godraj
    Don't know if you were aiming that at the specific application or Metra in general. The harness for mine was top-notch and their support was really helpful.
  1. Replies: 40
    Last Post: 07-03-2006, 07:38 AM
  2. Replies: 4
    Last Post: 05-17-2005, 05:17 AM
  3. No headunit or amp?
    By kefka_killer in forum Car Audio
    Last Post: 06-28-2004, 01:50 PM
  4. Headunit vs. Amp
    By Avalerion in forum Car Audio
    Last Post: 06-26-2004, 11:24 AM
  5. headunit vs. Amp
    By lstrunk in forum General Hardware Discussion
    Last Post: 06-05-2001, 03:30 PM
