Results 11 to 20 of 30
Thread: Alumapro
  1. #11
    Apr 2005
    Queens, New York
    Quote Originally Posted by Red GTi VR6
    it should be OK, but why wouldn't you?
    if you're going to be in there replacing the alternator in the first place, it's not going to be that much additional work at all.
    Battery to chassis is super simple.
    Alternator to battery positive can be done while have everything apart to replace alternator.
    And chassis to engine will be about as easy as battery to chassis.
    All it requires is some wire and some ring terminals.
    I have a 2002 Galant. But i ahve to install inline fuses though rite? What exactly is Chassis to engine?
    So basically then neg term on the battery goes to the chassis,
    The alternator pos goes to battery pos
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  2. #12
    Apr 2005
    Queens, New York
    What rating should the fuses be at?, and whatever is connected to my battery currenty, just goes right back on after the big 3?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  3. #13
    Oct 2004
    NY
    yeah, these upgrades become real necissary to get the benifit of the bigger alt....
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    Chassis to engine: your car will have a grounding point on the block. This is usually fairly small or a flat braided wire.
    As for the fuses, the only one of the big three that you might consider fusing is the alternator to the battery, and even then, it's only if you really want to. For competition, it's a must, but for the average every day Joe, not a necessity.
    As for the rating of the fuses for the rest of the stuff in the car like your computer and car audio stuff, total up your total current draw (amperage), and get a fuse close to that (a little over is ok, but nothing major - say your computer pulls 15 amps, a 20 amp fuse would be ok). There's also the thought of fusing the wire and not just the components, in which case you would use a fuse that would protect the wire from burning up....if you're interested in doing that, would need to find a chart that would describe all the different fuses needed for the different size wire....or just ask specifically and I or somoene else can answer.
    As for the size wire to use, specifically for your grounds, ALWAYS use the same size if not larger than what your power is. Remember, it's one continuous loop, if you go smaller on one area, you will create a bottle nexk.
    Jan Bennett
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    FWIW:
    The proper Gauge Wire based on current demand and length of run:
    The proper battery size based on total RMS wattage of system:
    The proper alternator size based on total RMS wattage of system:
    Jan Bennett
  6. #16
    Apr 2005
    Queens, New York
    so my system is basically 1300w RMS and it says i just need 110 alty, im getting a 180 so i should be good then
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    sheesh - a 180 amp alternator is WAYYY more than enough on your system.
    if you can get a smaller one for less $$, I'd consider it....lol
    Jan Bennett
  8. #18
    Oct 2004
    NY
    no, thats upgrade.... over & above what's there.... so there saying you need a 190.... you'll be fine...
  9. #19
    Oct 2004
    NY
    I think there over rating it.... there saying that you need 10 more amps just to add a 100w amp
  10. #20
    Oct 2004
    NY
    a 180 will definatly do it all on it's own, & you won't need any bandaids like a cap really.....
  1. F/S - Alumapro 15F CAP. A MUST HAVE
    By neema12 in forum Classified Archive
    Last Post: 07-08-2005, 11:33 AM
