Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Alumapro
    Apr 2005
    Queens, New York
    Alumapro
    Sup guys, I just picked up a JL 1000/1 JL 300/4 and a 12w7. I have a stock alernator but in my engine bay I have an optima blue top. I dont wanna kill my alternator.
    I have a 1 farad monster cable CApacitor. I was told that wont doo much, is that correct?
    How do you guys feel about the alumapro 15farad cap? Will that help me out big time? OR will I be ok with the 1 farad cap and the jl setup?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Apr 2005
    Queens, New York
    DOes it actually work? Or would it be better to install a 170amp alternator?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Oct 2004
    NY
    I personally love the alumpro 15... I used an alumapro 5 in a car I built that was at 1200rms, & it made a nice difference....
    Apr 2005
    Queens, New York
    Quote Originally Posted by turbocad6
    What would you do? INstall the alumapro 15 or get a Hight Output alternator? The alumapro I can get for $350 and the alternaotr i can get for $350...which would be better?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Oct 2004
    NY
    hmmmm, that's a loaded question, need more details like what's the stock alt putting out now, what's in the car for a battery now? then theres still a few ways to approach this.....
    if all you want to spend is the $350 & not have to do anything else I guess the alt sounds like a safe bet....., but personally if the stock alt is 110 or 120 amps & is in good shape, I would consider mounting a battery in the rear & a cap..... shouldn't need an alt upgrade at that point.... that's if you have the room for a battery.....
    either that or a heavy duty battery up front & 0 gauge run to the rear..... with a cap should be ok on a good factory alt.... your only talking 1,300 rms......
    if it's got a wimpy 70-85 amp alt then the alt may make more sense...
    Apr 2005
    Queens, New York
    My stock alt is 80amps, I have an optima blue top as my battery. I think if i upgrade my alt to 180amps then I will be good, Currently i have a 1 farad cap.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Cheekz185
    a 1 farad cap doesn't do jack, caps really don't do jack until you get to the level of the 15 farad caps you're looking at.
    Personally, I'd spend the money upgrading (either buy a new one or have yours rewound) alternator, THEN I'd consider the cap. Upgrading the big three is a must when running big systems
    see here for more information: http://forum.sounddomain.com/forum/u...=5;t=007801;p=
    hope this helps.
    Jan Bennett
    Oct 2004
    NY
    yeh, with an 80 amp stocker & that jl1000 an alt is probably the way to go.....
    Apr 2005
    Queens, New York
    Quote Originally Posted by Red GTi VR6
    hope this helps.
    What if I get a 160amp alty and dont do the big three? Will that be ok?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    it should be OK, but why wouldn't you?
    if you're going to be in there replacing the alternator in the first place, it's not going to be that much additional work at all.
    Battery to chassis is super simple.
    Alternator to battery positive can be done while have everything apart to replace alternator.
    And chassis to engine will be about as easy as battery to chassis.
    All it requires is some wire and some ring terminals.
    Jan Bennett
  1. F/S - Alumapro 15F CAP. A MUST HAVE
    By neema12 in forum Classified Archive
    Last Post: 07-08-2005, 12:33 PM
