Results 1 to 10 of 14
Thread: Power AMP from CarPC
    Jan 2006
    Michigan
    Is anyone running one power feed to thier carPC and then powering touchscreen and amp from the carpc's psu ?
    I know you can power a lilliput from the carps psu, but Im thinking my M1 psu may not have the juice to power a small amp.
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    Yeah, um...thats not gonna work.
    Jan 2006
    Michigan
    Can I do it if I upgrade to a bigger PSU , like the M2 ?
    Mar 2005
    Alabama
    Why do you want to? If its in a car, it will be 100 times better to power it straight from the battery.
    Feb 2006
    Why would you want to? Amps suck a lot of juice. Way more than you would want to supply from a computer PS. Besides, they are made to work off unregulated power. They either have their own internal DC-DC PS or they are made to take however much voltage you supply. Because of this, many amps produce more than rated power since you are supplying 14.4 instead of 12V.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    If your talking about powering your amp off a power supply:
    wtf would you put a power supply on an amp when an amp already has a power supply?
    If your talking about powering your amp off a regulator:
    wtf would you put a regulator on an amp when an amp is designed to work in the car environment?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Mar 2005
    Alabama
    Maybe we misunderstand you, do you mean you want to power your amp off your PSU, or do you mean you want use your PSUs built in SDC to turn your amp on and off. The first one is ridiculous but the second is fairly easy.
    Jan 2006
    Michigan
    Im talking about running the power from the battery, to the carpc and then running a line from the carpc to the amp. sounds straight forward to me, cept for the fact I may not have a big enough power supply in the carpc.
    I thought i'd seen someones schematic of this being done somewhere but cant find it anymore.
    Mar 2005
    Alabama
    I can see no point in doing that whatsoever. Just power your amp straight off the battery.
    Aug 2005
    Anaheim Hills, Ca
    If powering a car audio amplifier off of a computer's power supply seems straight forward to you, than i'm sorry. At some point you have to stop and ask yourself, "What was i even thinking? From now on, i'm not going to think out loud".
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. Replies: 2
    Last Post: 02-26-2006, 11:32 PM
  2. Replies: 9
    Last Post: 12-19-2005, 02:00 PM
  3. Replies: 1
    Last Post: 06-25-2005, 02:20 PM
  4. P 1280 AND an inverter to power my carpc, make sense?
    By Will Albers in forum General MP3Car Discussion
    Last Post: 05-24-2005, 12:50 PM
  5. how best to power my amp?
    By MP3 MOBSTER in forum Car Audio
    Last Post: 12-08-2004, 11:32 AM
