Results 1 to 7 of 7
Thread: using speaker wire as power wire
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    just was wondering if it would be ok use 12-14 ga speaker wire for low power accessories or is it a big "NO NO"...like for a 7" monitor or slot load dvd etc..
    I was just wondering because it seems like it is hard to find good quality 12-14 ga power wire (lots of thin strands) seems like they all are very course..and there is lots of good quality speaker wire that gauge..Very flexable Plus all you have 1 wire to mess with.
    If not what is the reason that you should'nt.
    Is the wire or insulation any different between speaker wire & power wire?
    Just was wondring.....
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why not?
    7" monitor and dvd doesn't require lot of current.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Variable Bitrate rcdash's Avatar
    Dec 2004
    At 12-14V, insulation is not an issue - the gauge and current draw will determine how much the wire heats up.
    For little stuff, that gauge is probably overkill - will work fine.
    Feb 2006
    Speaker wire is a good solution when you need to run both hot and gnd together. Wish I would of thought of that.
    BTW, I have found the best place to buy wire and wire connectors is home depot
    Mar 2006
    LEEDS UK
    i use a 100m roll of speaker wire i purchased a coupke of years ago, i use it for everything!
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    i used speaker wire to wire up **** on my bike :-)
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    i'm going to do the same thing for my screen & backup cam.
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
  1. Replies: 2
    Last Post: 06-29-2005, 10:28 AM
  2. Opus wont power, green wire has constant 5v???
    By jedi7001 in forum Power Supplies
    Last Post: 02-22-2005, 11:30 AM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Power WIre through firewall
    By Murphy3603 in forum Power Supplies
    Last Post: 10-27-2004, 01:18 PM
  5. Ignition Power Wire Location
    By djXternal in forum General Hardware Discussion
    Last Post: 08-11-2004, 07:08 PM
