Results 1 to 10 of 14
Thread: 00 Eclipse with Infinity system...please help
    Mar 2006
    Here's the deal: I want to replace my factory headunit and put new door and rear speakers in. I know that normally with the infinity systems you have to bypass the factory amp and run new wires to every speaker when you replace the head unit. I also found that you can buy a MITAH (http://www.discountcarstereo.com/detail.aspx?ID=434) to replace the factory "Infinity Radio" with an aftermarket headunit or to retain the factory radio and install an aftermarket amp and speakers. But I want to replace the headunit AND install new speakers... so am I stuck with rewiring the whole car or what? Thanks...
    May 2005
    The MITAH unit just converts the signals from the aftermarket headunit into the factory DIN plug. You can upgrade your speakers with or without it however the factory amp can't power aftermarket speakers well and you will very easily blow them due to distortion.
    If you haven't already, check out http://www.club3g.com. They have a car audio forum for the 00+ Eclipse, I'm the mod there.
    Project 1: 2002 Dodge Ram 1500 w/ 15" LCD (finished)
    Project 2: 2000 Mitsubishi Eclipse w/ 8" LCD (finished)
    Project 3: 2000 Pontiac Grand Prix GTP w/ 8" LCD (finished)
    Project 4: Dodge Ram Repair
    _
    Mar 2004
    Little Elm, Texas
    for the benefits, it's not a whole lot of time to run new speaker wires.
    Just go ahead and run em.
    Jan Bennett
    Low Bitrate sxt173's Avatar
    Feb 2005
    New York
    Yeah, I agree, run 'em. Have a 00' Eclipse and the MITAH option is ok, but factory amp is not suitable to use with non-factory speakers.
    I tried pretty much everything I could think of to (in my case) have an AUX-in.
    Easiest and best option would have probably been new headunit, amp & speakers.
    C134 Case
    VIA EPIA M10000
    FrodoPlayer
    iGuidance + GPS
    7" touchscreen LCD
    2000 Mitsubishi Eclipse GT
    - V6 216hp
    - KYB-AGX adjustable struts
    - Konei Alloy 17" rims + Pirelli P-Zero's
    - AEM slotted brakes
    - AEM CAI
    Jun 2004
    Rochester
    If you can locate the factory amplifier you will have direct access to the speaker wires there without rewiring anything.
    It looks like the amplifier in your car is probably underneath the front passenger seat. You probably won't be able to get a harness adapter for the amp>speaker connection, but you can cut that connector off and look up the wire colors on a wiring diagram to see which wires go to what speakers.
    Here is the radio wiring diagram for your car.
    2000EclipseWithAmp.pdf
    Peace.
    Jun 2005
    chicago, Illinois
    There happens to be a harness that can plug right into the speaker side harness going into the factory amp. That harness is actuall a Daewoo harness. The only thing about that is that you have to repin the harness to get the right lines which really isnt that hard.
    PROGRESS:
    Mar 2006
    Off topic.. but what kind of speakers did you want to get? I have infinity 63.7i 's and infinity 693.7i 's and they rock..
    Jun 2005
    chicago, Illinois
    Considering the topic of this thread, he's probably using the factory provided infinity speakers that came with the car as stock.
    PROGRESS:
    Mar 2006
    Quote Originally Posted by pancit175
    Yes but he said he wants to put new rear and front speakers in.. so i asked him what kind of speakers hes thinking about choosing..
    May 2006
    I also Have a problem
    I have 2002 Spyder, with After Market INFINITY system, But I want to Replace the head to a new kind a DVD.. I know there is an AMP somewhere in a car, and the hole Wire system is too complicated, I visited one of the Electric Shop, and the guy Told me he Don't want even touch it.. I allready discconected My old Infinity, I need some one who can little bit explane me hot to connect hole system to a Speakers, I know I can Find the amp and disconnect wires after then Connect speakers directly to a Head, but I'm not sure this Head will play aford Infinity..
    Any sugestions?
    Thanks in advance.
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 02:39 PM
  2. FS or FT: Kenwood kdc-mp828 & full infinity system
    By adidas445 in forum Classified Archive
    Last Post: 09-23-2005, 11:11 AM
  3. Ground noise in system
    By TyBong in forum General MP3Car Discussion
    Last Post: 09-20-2005, 03:13 PM
  4. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 03:15 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
