Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Sound Card and Digital Processor
  1. #11
    Sep 2003
    Small Town, MN
    i am in the same boat right now. However, I dont want to have to spend 6-700 bucks to get this setup. I also dont want to have to have a display/controller. Its too bad there are not really any other options out there.
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i will probably be selling my pxa-h700 really soon. i'm trying a different route that we've been discussing in another thread. I'll be going 4v out from soundcard on balanced lines directly into my amp. sooo... let me know, i think the going rate for a used alpine is about $350 bucks but i'm not sure.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Red GTi VR6
    and a good tune (as with audio systems) is CRITICAL...wegained 125 rear wheel hp with a good tune on ours...
    holly crap.. you are talking about a s/c and a good tune...not just a good tune...right?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  4. #14
    Feb 2006
    You can run with the c701 completely disconnected. You would then have to use the computer for volume but it would work just fine that way.
  5. #15
    _
    Mar 2004
    Little Elm, Texas
    a engine tune with the Paxton S/C set-up on a completely stock motor. Slapped it on there, set fuel pressure to read 50 psi at idle. Set the MSD BTM. Then went to the dyno and with someone who knows what they are doing, JUST tuning the aux injectors with the Split Second controller and the BTM timing unit, we gained an ADDITIONAL 125 rwhp.
    tuning is EVERYTHING
    Jan Bennett
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by EricE
    I guess this makes sense, except for when you want to make changes on the fly...like with sub level, etc
    Jan Bennett
  7. #17
    Dec 2004
    Los Angeles Ca
    wow... i have never heard of such a vast difference with just tuning. that is pretty incredible...time to drop a dodge engine into my car
    makes you wonder how much they detuned the car at the factory. i'm still in shock...
    ...sorry, back to your regularly scheduled thread
    M10k
    My Car Pc Install
    My Boat Pc worklog
  8. #18
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by WebGeek
    I spent $400 for my setup and have seen them go for as low as $315 in the classifieds....and my controller is velcroed away out of sight when not in use (it's not that big really).
    The way i see it...there's really no excuse for wanting one but not getting one. IF you want one, get one...it will be worth it and you won't regret it...many can vouch.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    see, the normal S/C kit only comes with a pair of 35# injectors, we haven't even touched the inside of the motor, hell, the valve covers have never even been off. We're still running the stock performance PCM, and it's not even tuneable.
    we ended up having to go to 53# injectors up top and 24# injectors on the motor.
    and we're STILL not getting enough fuel from the tank, need to either go with a dual pickup or a larger stock pump...
    345 rwhp/ 365 ft. lb. on a motor that dynoed something like 175 rwhp/ 290 ft. lb.
    it's been the same motor from back in the 70s retrofitted for fuel injection...lol
    Jan Bennett
  10. #20
    Dec 2004
    Los Angeles Ca
    i agree. thats why you should buy mine. seriously, the sound improvement is major. if i wasnt in a unique situation I would have been going to pretty extreme measures to keep this unit and make it work with my dash and keep it oem. thats how sold i was on it.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 11:54 AM
  2. Sound Card with S/PDIF
    By unixxx in forum Car Audio
    Last Post: 01-01-2006, 10:15 PM
  3. sound card help...
    By pimpmode in forum General Hardware Discussion
    Last Post: 06-01-2005, 11:32 PM
  4. Replies: 10
    Last Post: 01-21-2005, 04:27 PM
  5. digital sound question
    By amrit50 in forum General Hardware Discussion
    Last Post: 02-18-2004, 11:54 PM
