Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Dimming headlights
  1. #31
    Jun 2003
    did you replace the wire from the negative pole of the battery to the body of you car. if not you get this problem.
  2. #32
    Feb 2006
    Hmm, I think I'm gonna have to do the big three and see if that helps my situation. Whenever I play "Hip Hop Drunkies" by The Alcoholics, at high volume, my "check Gauges" light comes on, so I ckeck, and my stock battery gauge is all the way to the + side... this has happened twice in the last week. I'll see if I can do the big three tomorrow. It's an 04 dodge dakota with 130 amp alternator and the system is sopposed to be a total of 550 RMS. Nothing bad has happened yet, still have full power, no dead battery, etc.
  3. #33
    _
    Mar 2004
    Little Elm, Texas
    sounds like it's over charging
    which could be indicitative of a regulator going out on your alternator or other things
    Jan Bennett
  4. #34
    Feb 2006
    Hmm, thanks; it's weird, it goes back to normal if I shut it off, then start it up again.
  5. #35
    Jun 2003
    it could be that the high current spikes are tripping the computer into thinking there is a problem but your dont see this on the ammeter becuase it is to is to slow to show them.
  6. #36
    Feb 2006
    That may be a good theory actually, if I watch the ammeter, I do see it fluctuate, but only like 1/8" at most; I haven't actually been watching when it kicks all the way over to the + side though. Would an aftermarket ammeter tell me anything more than the factory one or would it essentially be the same thing?
  1. Replies: 7
    Last Post: 01-24-2007, 10:31 AM
  2. Making Projector Headlights!
    By nFiniteTuning in forum Fabrication
    Last Post: 02-02-2006, 09:25 AM
  3. VW Owners / Dimming lights
    By TheSpatulaOfLuv in forum Power Supplies
    Last Post: 09-16-2005, 08:48 AM
  4. headlights on = lights dim = problem?
    By Song0330 in forum Newbie
    Last Post: 03-14-2005, 05:07 PM
  5. Lilliput + headlights = inerference
    By 4.9 EF Futura in forum LCD/Display
    Last Post: 07-02-2004, 12:53 AM
