Page 10 of 15 FirstFirst 123456789101112131415 LastLast
Results 91 to 100 of 148
Thread: 1/3 Octave Software EQ
  1. #91
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Genesisfactor
    i'm curious though, if we get a quaility line driver with the m-audio or whatever, and use a software eq (total cost seems to be about $700 for those to together), why in the world would a mom all in one solution cost more than $2-$3K???
    Also scott, way cool job man!
    a line driver IMO isn't a high end solution.
    Jan Bennett
  2. #92
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by scott_fx
    4) they run off of ac and it's not just a simple transformer inside that would could bypss with a dc psu.
    Actually, there are a few people who have converted these to DC and are currently running them in their cars and competing rather successfully with them.
    I'm speaking of the Drive Rack specifically.
    So there you have it... i think hardware wise we are getting close. keep in mind these boards have only two outputs so with most of us, we'll need 2 boards...getting us the $300 mark...not too shabby
    this just doesn't settle well with me. It might work fine for others, but the fact that you have to purchase multiple units, bothers me...more components = more possibility for problems and interference.
    btw - what is this guys (Doug) last name?
    does it start with a W?
    Jan Bennett
  3. #93
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Red GTi VR6
    i don't doubt it can be done, i just dont think that it will be as simple as bypassing the transformer and hooking up a regulated psu. The thing you were talking about specifically may be different or maybe some really talented people figured out how to power it. I'm just not one of them
    it starts with a 'S'
    i'll talk to him about a 4 chan unit and what the problems of 'two' 2-chan units would be.
    Just a side note, i'm doing all of this for you guys :-) the m-audio soundcard i purchased looks like it's going to work for me :-) but i really want to explore other possibilities too, that's why i'm doing this. Software eq and x-overs are going to be really important with this usb dac solution.
    hey red, when you tune, do you give each chan a different eq setting? or do they all have the same eq settings?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  4. #94
    Dec 2004
    Los Angeles Ca
    so i just got a reply from doug and he said that running two of these probably isnt a good idea...so much for my theory.
    the other place that i had linked to; stereo-link, had this to say:
    The line level out of the stereo-link is 2V rms, the standard line level out for home audio systems (eg CD players). The computer sound card standard is 1V rms.
    For clarification, the DAC uses 3 power supply voltages: 3.3V for the digital, and +/- % for the analog section. There are on-board regulators for each of these.
    We will be introducing a high-end audiopile version within a month that will have a more robust power supply running at +/- 8V, and the headphone output will be capable of a little more than 4 V out, but the cost will also be quite a bit more.
    Hope this helps.
    I guess that is why we are having such an issue with getting 4v. home audio gear isnt boosting there signal to avoid noise...since it's a clenaer environment.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  5. #95
    Dec 2004
    Los Angeles Ca
    ok, me again...
    so doug is freakin awesome. he already replied. here is the email conversation we had and his solution:
    from doug:
    I'm not sure what you mean by a four channel version. If you mean 4 channels of decoding (quadrophonic rather than stereo) I don't think it can be done, but I also don't know of any recordings that are quadrophonic since the early 70's. If you mean having 2 sets of outputs, you can simply parallel the outputs and connect two wires coming out of each channel. You could also use a Y cable of some sort.
    As for running 2 at a time, I doubt you can run 2 usb soundcards at once. To do it, you would need to configure something at the computer itself. Also, you would need to have some extra current as this card, because of the opamp, buffers, and dac will not play well with other usb devices. The TDA1543 draws about 50ma, the amp portion will probably draw a little less than that, and the pcm2707 will draw a little. If you consider that usb can supply 500mA at 5V, that this soundcard is converting that 5V to 14 or 18V at about 70% efficiency, this means that you only have about 125 to 150mA to work with. It should be fine for one, but I doubt for 2.
    Doug
    my reply:
    well, the common setup in car audio is to have a set of outputs for the front door speakers and output for the sub. (acutally ther are another set for the rear speakers, but we arent concerned about that. Our problem is that we'll need these outputs at 4volts and also to cross them over on the software side of things (that we would have to take care of). if we split them off with a y-cable then we'd be sharing the power to each input, effectively cutting the voltage in half (is my hypothesis correct?). we could always just build an x-over after the amp but before the speakers but we were trying to have the cleanest/streamlined solution as possible.
    No, the 2 voltages in parallel are equal. However many outputs you put in parallel, they will all have the same voltage across them.
    However, you can only draw so much current, and if you go into 2 inputs from one output, the amount of current that can be drawn for each output is cut in half. However, the buf634 can provide a ton more current than you will ever need (about 250mA), and you will reach the limits of the usb long before you begin to stress the buffer.
    The software crossover would not be possible, however. My advice would be to use a cap (in parallel) and a resistor (in series) to make a low pass filter on one of the parallel lines out. Way less work and sounds better too.
    -d
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #96
    _
    Mar 2004
    Little Elm, Texas
    as for the question about tuning - yes, each SPEAKER has it's own EQ setting....each speaker is also on it's own independent channel as well. (4 channel Audison)
    as for the rest - will read it once I get to work - don't have time right now.
    Jan Bennett
  7. #97
    _
    Mar 2004
    Little Elm, Texas
    ok - had a chance to read this...
    the idea of takinga single output and splitting it to multiple channels isn't ideal IMO, but I don't REALLY see anything wrong with it....
    just would prefer dedicated outputs is all...
    after all - stereo is stereo...
    5.1 or DTS is a different story though
    Jan Bennett
  8. #98
    Dec 2004
    Los Angeles Ca
    well, here is some more brain food. this one was a reply from a company called 'echo audio' whom makes soundcards that are pci or firewire (so that covers you red):
    Hello Scott,
    Sounds like a cool setup. We are planning on adding a "bass management"
    feature to our console which would probably be able to do what you're
    looking for. But, that is a long ways in the future. We really haven't
    had any demand for something like that. Here are a few other
    possibilities that come to mind: If you're just playing out of Windows
    Media Player, they have some built in EQ and you might be able to find a
    plugin to do what you're looking for. I'm not aware of software that
    does exactly what you're looking for. But, you might be able to use
    standard recording software with "rewire" support to pipe audio into the
    software, filter the channels and pipe it out the sound card. You might
    also play out of our digital output, loopback into the digital input,
    record into your filter software from the digital input and play out the
    analog output.
    Sorry we aren't aware of a simple way to do what you're looking for.
    But, there must be a way to make it work! Layla or Gina3G will both
    work for everything described above.
    i think we should all look into the whole 'rewire' support now
    here is echo's website:
    http://www.echoaudio.com
    M10k
    My Car Pc Install
    My Boat Pc worklog
  9. #99
    Dec 2004
    Los Angeles Ca
    this was posted in my thread about adding vst support to centrafuse:
    i'm totally with you on the vst plugins. the're are numerous high-quality plugins available.
    I use a soundscape mixtreme 192 (http://www.sydec.be), a soundcard which can process native use of vst plugins. great!! using a 'tube warmifier' plugin right now, absolutely amazing!! downpart are the drivers (at the moment), which doesn't support hibernating...
    But sound uality is superb and you can always upgrade the external D/A converter
    if i'm reading this right, we can use the vst plug-ins if we get this card...now just to find out what options are available
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #100
    Dec 2004
    Los Angeles Ca
    last bit of GREAT info from the echo people (they have been so helpful)
    MY EMAIL:
    > sorry, me again.
    > one last question. what is the voltage output on the balanced outputs?
    > thanks,
    > scott
    ECHO'S REPLY
    Approx 5.75Vrms
    Your laptop should be OK for this application.
    Thanks for your inquiry.
    you guys would need to convert the balanced to unbalanced but 5.75Vrms!!
    not bad for those of us that can use pci cards... ~$270
    if we can get a good software eq and x-over, we could have a better and less expensive option then the alpine (plus we can control everything from the computer)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  3. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 04:09 AM
  4. Are there any software EQ solutions?
    By The Grinch in forum Software & Software Development
    Last Post: 07-07-2004, 11:02 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 11:17 PM
