Page 13 of 15 FirstFirst ... 3456789101112131415 LastLast
Results 121 to 130 of 148
Thread: 1/3 Octave Software EQ
  1. #121
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Quote Originally Posted by Vinister
    What if we could use the PC as the controller, like we do with the XM tuners? What if we could devise a USB --> H701 cable? Wouldn't that be the holy grail?
    Anything that uses an IR remote can easily be controlled by PC. Can't the H701 controller use the Alpine IR remote? If so, that's the easiest way. I'm not sure the various AI-net efforts have gotten anywhere yet.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  2. #122
    Registered User
    The h701 cant be controlled with a remote, that would have been nice though
  3. #123
    Dec 2005
    Hmmm I had another idea. I used to dabble around in producing techno music quite a bit. I mostly used a program called propellerheads reason. Its an amazingly fun program to work with, extremely visual, sounds great, and can be had for free at the usual places.
    Good suggestion. Unfortunately, the product's eq (at least in the latest 3.0 software) appears to be 4-band parametric...not the 1/3 octave that we're looking for. And, for the non-pirating folks, the price tag...$500. If all you wanted was a 4-band parametric, Anwida's stand-alone EQ is only $100.
  4. #124
    _
    Mar 2004
    Little Elm, Texas
    my problem with software is just that it's hard to work with, especially on a 7-8" screen.
    Having to tune a system with so many different controlls on screen and do it on a small screen, would be a nightmare.
    I'd LOVE to see this work, but I'm just thinking about implementation.
    Other than remoting in and changing settings, it just seems like it's going to be a PITA.
    I'd LOVE to be able to controll the Alpine via the PC, but again, it would have to be made incredibly simple. Touching and dragging just won't cut it. It won't be easy to be exact with what you want.
    Have these thoughts crossed anyone elses mind?
    Jan Bennett
  5. #125
    Aug 2004
    You think using the controller that comes with the H701 is simple? I've been so lost in those menus trying to set everything up properly, always guessing which button does what. IMO Alpine knows nothing at all about intuitive user interfaces. The only good thing about the controller is that at least it features a volume knob.
    I downloaded the anwida EQ and found it to be a pretty cool tool, even though I couldnt get it to work properly. There was no way for me to seperate the raw sound playing from the EQ'd sound, so it was just stacking up and giving me crazy feedback. Buuuut.... I ended up playing around with making crazy computer feedback sounds for an hour, filtering them this way and that. zzzzrrrrrrmmmmmmwwwwwoommmmwowoooommmwooooommmm... .. fun stuff.
  6. #126
    _
    Mar 2004
    Little Elm, Texas
    once you know what you are doing, it's a VERy simple piece to use, more intuitive than a LOT of others out there on the market right now.
    Compared to trying to make adjustments on a 7-8" touchscreen with a bunch of sliders, yes, it's a LOT more simple.
    Jan Bennett
  7. #127
    Aug 2004
    I dont know if I agree. I've worked with dozens of H701s and I've hated every minute of it.
    Maybe you should consider a better input device for your computer. A ball mouse flushed into the center console, for example, changes everything. On screen sliders and knobs can be great.
    I've been working with the new Zapco amps recently, they have no adjustments on the chassis, everything is done through a USB connection to your laptop (or carpc).
    edit... check out this zapco peice. programmed by an incredibly nice app for PC. It gives you full control right onscreen.
    http://www.zapco.com/prod/DC_Ref/DSP_DRC_Frame.htm
  8. #128
    _
    Mar 2004
    Little Elm, Texas
    A ball mouse would be incredibly finicky IMO.
    Focal has something similar out now to the Zapco.
    We're just waiting for a production run to be avaliable...have some to a team member for testing in the near future.
    Jan Bennett
  9. #129
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    would that run in the background?
    and does it have a crossover?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  10. #130
    _
    Mar 2004
    Little Elm, Texas
    which one? Focal or Zapco?
    Jan Bennett
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 04:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 01:38 PM
  3. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 03:09 AM
  4. Are there any software EQ solutions?
    By The Grinch in forum Software & Software Development
    Last Post: 07-07-2004, 10:02 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 10:17 PM
