Page 14 of 15 FirstFirst ... 456789101112131415 LastLast
Results 131 to 140 of 148
Thread: 1/3 Octave Software EQ
  1. #131
    Aug 2004
    The zapco one gives lets you specify your crossover points, slopes, and gives you a graphic view of what's happening. Same for the EQ. The software is very solid, well developped, and straightforward to use.
    we're also eagerly awaiting the new Focal amps. Big chunks of machined audio sex....
  2. #132
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
  3. #133
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    Did anyone follow through with any of the sofware suggestions in this thread? I'm just curious to see if people found a solution that works for them.
  4. #134
    _
    Mar 2004
    Little Elm, Texas
    I know I didn't
    lol
    Jan Bennett
  5. #135
    Low Bitrate Aetherion's Avatar
    Jul 2006
    Armidale NSW Australia
    I know Red and Scott have seen this, but I wanted to subscribe to this thread, so I thought I'd put this here as well, in case anyone on this thread has any ideas on how to make this possible.
    (What are we trying to make possible? Sending a multiple channel signal out from the carPC through a SPDIF output, preferably through a single cable, to a device that takes the signal and converts it to multiple channels of Analogue RCA output, high voltage, to go straight into the amps. 5 or more stereo channels would be ideal. Hope that makes sense... Should solve the hardware side of things if it works...)
    can a carputer compete with a head unit for sound quality?
    Let's see how much a carPC can REALLY do...
  6. #136
    May 2006
    Dartford Kent
    Im not sure if this has been mentioned as yet but the processor im using is a Dehringer DCX2496, it has 1/3rd octave eq for each channel output, active crossovers, variable crossover filters & slopes from 6db to 48db, time alignment plus a whole load of other things, but the best part is it can hook into a pc & with the free software all the units functions are controled from the screen. The only downside is it doesnt have a very strong preamp stage but as ive got almost 11 volts of signal im not that fussed.
  7. #137
    _
    Mar 2004
    Little Elm, Texas
    do you have a pic of your install by change paradyme5401?
    Jan Bennett
  8. #138
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    isn't it a Behringer :-)
    how did you power it? inverter or did you pay $$$ to have someone convert it to 12volts?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  9. #139
    Jul 2006
    As far as hardware goes I may have found a solution that would mean (I think) that you wouldn't even need a soundcard, and that would give 16 Analogue RCA outs, with 24bit/96khz capability, and all you would need is 2 Firewire ports on your PC, plus of course, the necessary software.
    http://www.creamware.com/
    check out the A16Ultra...
  10. #140
    Jul 2006
    LOL - ooops, those aren't RCA's.... Still usable though?
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 04:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 01:38 PM
  3. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 03:09 AM
  4. Are there any software EQ solutions?
    By The Grinch in forum Software & Software Development
    Last Post: 07-07-2004, 10:02 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 10:17 PM
