Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 148
Thread: 1/3 Octave Software EQ
  1. #31
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    just got a reply from m-audio and they said that you can run the balanced outputs to an unbalaced source which will give it the 4v outputs from a soundcard.
    i also talked to some people about creative's prosumer line 'emu' and they said that the emu's were a hard product to beat except for one ore two things that pertained to audio recording...i forgot what they were though :-)
    so red you should look at those because they do have pcmcia (if memory serves me right) and they probably have 4v balanced outputs. now we can take advantage of the software eq'ing... onto that research now.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #32
    Dec 2004
    Los Angeles Ca
    for those of you following this thread, i'd like to link another thread that kingeorge36 just started, sounds promising:
    Directdvd 6 HD possible in car EQ???
    Quote Originally Posted by kingeorge36
    I don't usually post here a lot, but I was reading that in the new version of Directdvd 6 HD software it allows each speaker to have it's own 31 band EQ.
    If this was true this would be a cost effective eq for anyone's carputer. Not to mention a very versitile picece of software as well because it play any type of the common media (DVDs or CDs) and still give you the 31 band EQ for each speaker as well.
    Here's link to the info:
    http://www.orionstudios.com/31BandSurround.html
    M10k
    My Car Pc Install
    My Boat Pc worklog
  3. #33
    Low Bitrate Mandos's Avatar
    Sep 2005
    Coralville, IA
    If the software used to play CD's supports VST plug ins:
    http://www.voxengo.com/product/glisseq/
    http://www.voxengo.com/product/curveeq/
    Plus they have a pretty good software TA solution
    Chris Schempp
    Elemental Designs
    Scion tC in progress
  4. #34
    Mar 2006
    NC
    Well, Its been established that M-audio is a good company but I'll just add my 2 cents in. My wife used to work for a music software company and exclusively used M-audio equipment. I was VERY impressed with it and would recommend it to anyone.
    I know I was amazingly shocked when I hooked up my digifire 7.1 card to my system. It sounds great even without a signal booster.
    I have also looked as the PAS equalizer studio. Its some serious stuff. It has a 31 band eq just for the low frequencies. You can also hook in a mic and have the program automatically adjust your system to a curve you set or what it deems "right." I personally appreciate how an artist wants their music to sound and listen to it that way. There is a free trial so you can give it a shot. http://www.pas-products.com/
  5. #35
    Nov 2005
    New Zealand
    http://www.m-audio.com/products/en_u...e410-main.html
    http://www.m-audio.com/products/en_u...1814-main.html
    Maybe one of those would be suitable for replacing a standalone processor. I imagine the drivers for these might have the features you're looking for?
    Also, doesn't the 3rd party Soundblaster driver set have things like this? I can't remember what they're called, but they have a lot of features aimed at high-end audio, and from memory use ASIO as well.
  6. #36
    Dec 2004
    Los Angeles Ca
    i think you're talking about kxproject. i'm not sure though, havent checked into that in a while. the catch to the kxproject drivers is that it will only work with pci-based sb cards.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  7. #37
    Dec 2004
    Los Angeles Ca
    M10k
    My Car Pc Install
    My Boat Pc worklog
  8. #38
    Nov 2005
    New Zealand
  9. #39
    Low Bitrate TechToy's Avatar
    not sure if you're purely looking for a software eq or a HW/SW combo..
    I do a bit of pro audio, and i absolutely love my Sabine Graphiq.
    2 channel, 1/3 octave, compressor, limiter etc...
    the only things on thr front pannel is a serial port 5 LED's and power button..
    also has dry contact inputs for memory recals..
    all curves /adjustments are done via serial port and the software..
    http://www.sabine.com/GraphiQ2/GRQ2-main.htm
    i use the GRQ-3122S..
    and no it's not cheap..
    approx 1200.
    but worth every penny..
    TechToy
    2005 Explorer
    Proudly using Centrafuse
    DWW-700M + Sony XM-SD46S &
    pre-amp, XM100D
    and Icom PC1000
    Yaesu 7100M
    Kenwood TM-641
  10. #40
    Mar 2005
    NY
    Quote Originally Posted by Red GTi VR6
    I posted in the general hard ware section asking if there were a sound card out there that has RCA outs directly on it. If I could find that (with enough juice from those RCA outs) then moving to a software set-up like this company offers would be very tempting!
    I havent' read far enough, but my Creative MP3+ has RCA outs only...and then one headphone jack. Still has potical though...i beleive it has spidif, but i doubt it
    and didn't i start a thread similar to this with a piece of software that i found and no one replied to:P.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  3. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 04:09 AM
  4. Are there any software EQ solutions?
    By The Grinch in forum Software & Software Development
    Last Post: 07-07-2004, 11:02 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 11:17 PM
