Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 41 to 50 of 148
Thread: 1/3 Octave Software EQ
  1. #41
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    hey red, i think some of the firewire m-audio cards have balanced 4 volt 1/4" trs (tip/ring/sleeve )outs. you could make a custom cable to make an unbalanced rca. each trs out is it's own channel (unlike the mini plugs on most soundcards that cary two chans)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #42
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Genesisfactor
    I havent' read far enough, but my Creative MP3+ has RCA outs only...and then one headphone jack. Still has potical though...i beleive it has spidif, but i doubt it
    This card doesn't do what I need it to. It only has a set of RCA outs I believe. This was the first response to my post about a 'high quality' sound card in the hardware forum. I responded to that guy as well.
    Jan Bennett
  3. #43
    Dec 2004
    Los Angeles Ca
    SO I'M AN IDIOT
    That m-audio card i purchased only has 2 sets of balanced outputs. Looks like i'll be going with the e-emu 1820 card
    M10k
    My Car Pc Install
    My Boat Pc worklog
  4. #44
    _
    Mar 2004
    Little Elm, Texas
    hahahaha
    that sucks!
    let us know about the e-emu card!
    Jan Bennett
  5. #45
    Dec 2005
    M-Audio balanced? outputs
    I learned something when talking to m-audio the other day. I have an m-audio mobilepre usb external soundcard that has two 1/4" output jacks. I assumed these were balanced jacks, but they told me they were not. I'm definitely not an expert on this stuff, but it was still surprising to me. I guess the morale is don't assume that all 1/4" outputs are balanced.
  6. #46
    Dec 2004
    Los Angeles Ca
    well...i'm doing a lot more research again. i have to make sure that i can get a software x-over as well, since my amps dont have x-overs. UGH.... i have a ton of emails going out. I may just end up keeping the alpine and going unbalanced into the amps (i would hack up the face plate so i could hide everthing but the volume knob)....id rather avoid this though.
    anyways, quack, i may have an m-audio soundcard for sale...it has balanced 4 volt outs :-) you can make a cable to convert it to unbalanced 4 volts for your amps if needed.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  7. #47
    _
    Mar 2004
    Little Elm, Texas
    if you hack up that alpine deffinately let me know!
    Jan Bennett
  8. #48
    Dec 2004
    Los Angeles Ca
    well emu just emailed me back and they dont have x-over ability in there soundcards! ARGH!!!! there is another problem with going 'pxa'-less.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  9. #49
    _
    Mar 2004
    Little Elm, Texas
    man - if we had the means and the money, we should design a high quality all in one solution to this problem!
    Jan Bennett
  10. #50
    Dec 2004
    Los Angeles Ca
    well...i can't help with the means...probablly not much with the money (relatively) BUT i can provide the problem....wait...
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  2. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  3. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 04:09 AM
  4. Are there any software EQ solutions?
    By The Grinch in forum Software & Software Development
    Last Post: 07-07-2004, 11:02 AM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 11:17 PM
