Results 1 to 2 of 2
Thread: audio specs help
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    audio specs help
    so my new amps have balanced inputs and therefore I am able to easily achieve a 4 vrms input from a soundcard. But I am wondering what are the important things to look at when researching them. this is what i am looking at:
    (note...if you have any recommendations for a soundcard (hopefully below $400 please let me know)
    http://www.ramelectronics.net/html/m...phile-192.html
    main outputs
    max output (balanced): +14dBu (3.9 Vrms)
    max output (unbalanced): +8dBu (1.95 Vrms)
    signal to noise ratio: -108dB @ 48kHz (a-weighted)
    dynamic range: 109dB @ 48kHz (a-weighted)
    THD + N: 0.0023%, 1kHz, -1dBFS @ 48kHz
    frequency response: +/-0.1dB, 20Hz to 20kHz @ 48kHz
    +/-0.1dB, 20Hz to 40kHz @ 96kHz
    +/-0.5dB, 20Hz to 80kHz @ 192kHz
    crosstalk: -105dB, 1kHz, channel-to-channel
    impedance (balanced): 300 Ohms
    impedance (unbalanced): 150 Ohms
    here is all the sc's info:
    The Audiophile 192 continues the legacy of M-Audio’s industry-standard Delta audio card line. Building on our Audiophile 2496—one of the world’s most popular audio cards—the Audiophile 192 features high-definition 192kHz sampling rate, digital I/O, balanced analog I/O and an amazing signal-to-noise ratio. The Audiophile 192 represents a new benchmark in audio performance that’s as good as it gets for music production, mastering and critical listening. As with all Delta cards, you get rock-solid drivers and seamless integration with your favorite Mac and PC applications—and even the ability to combine multiple Delta cards in one system*. And since M-Audio is always ahead of the pack, this world-class card is also compliant with PCI 2.2 and 64-bit audio drivers so you’re ready to take advantage of next-generation platforms and software. The Audiophile 192 is the new world-class standard in stereo audio cards.
    Features
    • up to 24-bit/192kHz audio
    • 2 x 2 balanced analog I/O
    • S/PDIF digital I/O with PCM and surround
    • direct hardware input monitoring
    • 16-channel MIDI I/O
    Specifications
    2 balanced analog inputs (1/4” TRS)
    2 balanced analog outputs (1/4” TRS)
    S/PDIF digital I/O (coaxial RCA connectors) with 2-channel PCM
    SCMS copy protection control
    digital I/O supports surround-encoded AC-3 and DTS pass-through**
    direct hardware input monitoring via separate balanced 1/4” TRS monitor outputs
    software routing of inputs and outputs
    digital I/O can be routed to/from external effects
    16-channel MIDI I/O
    ASIO, WDM, GSIF 2 and Core Audio driver support for compatibility with most applications
    64-bit driver support for Windows
    PCI 2.2 compatibility
    works with other Delta cards*
    * check www.m-audio.com for current system requirements
    ** Windows XP required for Dolby Digital and DTS “pass-through”; Mac OS 10.3.4 required for Dolby Digital and DTS “pass-through” with Apple DVD Player
    general specifications
    sample rates (kHz): 44.1, 48, 88.2, 96, 176.4, 192
    main inputs
    max input (balanced): +14.2dBu (4 Vrms)
    max input (unbalanced): +14.2dBu (4 Vrms)
    signal to noise ratio: -113dB @ 48kHz (a-weighted)
    dynamic range: 113 dB @ 48kHz (a-weighted)
    THD + N: 0.0006%, 1kHz, -1dBFS @ 48kHz
    crosstalk: -130dB, 1kHz, channel-to-channel
    impedance (balanced): 20k Ohms
    impedance (unbalanced): 10k Ohms
    main outputs
    Compatibility
    ASIO
    WDM
    GSIF 2
    Core Audio
    Pentium 3 – 700 MHz or higher, 256 MB RAM (192 and 96kHz operation)
    Pentium 3 – 500 MHz or higher, 128 MB RAM (48kHz operation)
    DirectX 9.0b or higher
    Windows XP (SP1) or Windows 2000 (SP4)
    Available PCI slot
    Macintosh G4 733 MHz or higher
    512MB RAM
    Mac OS X Jaguar (10.2.8 or later) or Panther (10.3.4)
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    bump!
    I'd like to hear some input on this as well!
    Jan Bennett
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. PCI Audio vs. USB Audio vs. Onboard Audio
    By waltwalt in forum Car Audio
    Last Post: 07-26-2007, 09:36 AM
  3. Strange audio issue
    By iamgnat in forum MacCar
    Last Post: 10-05-2005, 02:01 AM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  5. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
