Results 11 to 20 of 28
Thread: subs and Computers? do they mix?
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 3onDubs
    1. Use a laptop hard drive
    I don't think this is so much important. There have been debates raging for pages upon pages upon pages on this very topic, and not a solid conclusion has been come to yet.
    Jan Bennett
  2. #12
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    I also forgot to add that you should perform the "screw test" when the sub is in the sub box (as it would be in the car)....basically, just make sure that the magnetic pull is not significant enough to move a small object.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  3. #13
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by turbocad6
    the screw drop isn't acurate enough... the best way to really check is to dangle a washer on a string, if theres any pull at all you should see it..
    Turbocad is right...this is a much better method. Why didn't i think of that?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  4. #14
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    I'm using a 3.5 hard drive mounted on a bracket that is screwed directly to my sub enclosure for over a year now with no problems.
  5. #15
    Mar 2006
    Las Vegas
    i eat subs in my truck next to my computer all the time they wont do any damage... should be ok
    thank you come again
  6. #16
    Low Bitrate PCModifiers's Avatar
    Dec 2005
    Quote Originally Posted by gmax111
    Quiznos or Subway?
    No one ever said this stuff was easy...The Mobile Desktop
    Progress[**********]
    Dolby Digital Real-time Encoding*Desktop Computer*Athlon XP Mobile*ASUS A7N8X Deluxe*Kingston Hyper X*5.25" CDRW and DVD drives*Lilliput 8" LCD*Mag 14" LCD
  7. #17
    Mar 2006
    doesnt lead do something to block magnetic fields or is it just radiation?
  8. #18
    Jun 2005
    Michigan
    Steel does the best job of (passively) blocking magnetic fields. Though its fairly inconvenient to build a big steel box around your sub.
  9. #19
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Yes, it will work...but you will have to do the following 3 things:
    2. Properly deaden the surface behind and around the pc.
    3. Hold a screw half a foot away from your subs and slightly above their height level...drop the screw...if it hits the ground you're good to go. If it gets sucked onto the sub magnet, then you're going to have to move the computer further away.
    1. Don't have to
    2. Don't have to
    3. Don't have to
    I use a regular drive mounted on top of my sub enclosure. No problems with the magnet or vibration. My hard drive isn't even srewed down, its just sitting there, so it rattles with every hit of the sub or road bumps, and with new york roads that a lot of bumps.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  10. #20
    Aug 2005
    Anaheim Hills, Ca
    That's what im talkin bout...back in the ol days, we used to strap hard drives to our handle bars and do all kinds of crazy jumps wit no pro'lems.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. Will a car computer mix with subwoofers.
    By Jcarere in forum General MP3Car Discussion
    Last Post: 08-06-2005, 11:35 AM
  2. Question - Those with sound systems (subs) and computers....
    By animus in forum General Hardware Discussion
    Last Post: 05-19-2003, 09:07 PM
