Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Help - Broken male RCA tip in female plug!
  1. #21
    Raw Wave tj!2k4's Avatar
    Oct 2004
    yes.
  2. #22
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    tie it to your roof, connector 1st and then crash into a cliff at 150mph!
  3. #23
    Mar 2004
    Bristol
    or give the amp to NASA and ask them to tie it down in the airlock and open the door - maybe the connector will get sucked, sorry blown, out into space
  4. #24
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Quote Originally Posted by Scouse Monkey
    WTF!
    1 - you stole my idea
    2-matchstick = gay and will break
    1 - no I didn't, I said it differently and I dont' see any patents
    2 - a matchstick is only gay if you do an act with it
  5. #25
    Mar 2006
    Las Vegas
    use a wirefeed welder and spark an ark on the rca female jack then move ur arc across the jack to the hole then tack the end of ur wire to the pin and wait for it to cool... then pull it right out... whaaala... then use some solder to fill the big ******* u gave to ur amp... but first dont forget to use a gay matchstick with superglue on the end to perform an act with ur newly acquired *******... then fill it with the solder buttplug
  6. #26
    Oct 2004
    so edrex, it's been a while.. which method worked?
    *please say centrifuge*please say centrifuge*please say centrifuge*
  7. #27
    Oct 2004
    NY
    why not just thread the tip of a sheetrock screw into the little hole in the center of the broken pin & just pull it out?
  8. #28
    Feb 2006
    That's what I was gonna say!
  9. #29
    FLAC sama's Avatar
    Feb 2006
    London, UK
    or maybe wax it out?
  10. #30
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    maybe use one of these:
    i think they are called 'bullet' connectors
    just stick it an and pull it out...just like....nevermind
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Replies: 2
    Last Post: 12-12-2005, 06:44 PM
  2. Where to purchase high quality SHORT rca to mini-phono (1/8" plug) cables?
    By sivart321 in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:59 PM
  3. Replies: 2
    Last Post: 03-01-2005, 06:23 PM
  4. usb male to female stub plug
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-03-2004, 06:17 AM
  5. 3.5 stereo jack to 2 male RCA out?
    By judoGTI in forum General Hardware Discussion
    Last Post: 09-07-2004, 04:28 PM
