+ Reply to Thread
Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: Help - Broken male RCA tip in female plug!
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Unhappy Help - Broken male RCA tip in female plug!
    One of my audio cables broke the tip off in the RCA on my amp. The broken part starts about 1/8" from the surface and I can't find a way to get it out.
    Does anyone know of anything that I can try?
    Thanks,
    ed.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    sharp pointed tweezers? Best way though is probably going to be take the cover off the amp and push it out from the back, will prevent damage to the rca plug from fussing with it.
    肚子笑痛了
    S60 Install
    Raw Wave tj!2k4's Avatar
    Oct 2004
    crazy glue the part that's protruding to something else...?
    FLAC edrex's Avatar
    Dec 2004
    Thanks JC. There is no room for tweezers, and next to no room for getting behind it. I may have to desolder the plug and take it out, but I don't want to mess with it (read: mess it up) that much.
    Was hoping someone may know a trick or two for it.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    bit of super glue on the end of a matchstick?
    FLAC edrex's Avatar
    Dec 2004
    Quote Originally Posted by tj!2k4
    Hmmm... its a thought, although I would risk getting glue inside the plug and never getting it out.
    Oct 2004
    Quote Originally Posted by Scouse Monkey
    c'mon man! come up with something original!! you think just because you said "super glue" makes it different than my suggestion??!!!!
    lol
    FLAC edrex's Avatar
    Dec 2004
    I'm surprised he didn't jump on the "push it from behind" comment... more his style!
    Mar 2004
    Bristol
    i was trying to post that before you did. had a fookin login problem!
    You could try carefull drilling into the bit with a 1-1.5mm PCB drill then glue summit slim inside - like a paperclip.
    Mar 2004
    Bristol
    Quote Originally Posted by edrex
    CHUMBA!
+ Reply to Thread
  1. Replies: 2
    Last Post: 12-12-2005, 06:44 PM
  2. Where to purchase high quality SHORT rca to mini-phono (1/8" plug) cables?
    By sivart321 in forum General Hardware Discussion
    Last Post: 07-15-2005, 08:59 PM
  3. Replies: 2
    Last Post: 03-01-2005, 06:23 PM
  4. usb male to female stub plug
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-03-2004, 06:17 AM
  5. 3.5 stereo jack to 2 male RCA out?
    By judoGTI in forum General Hardware Discussion
    Last Post: 09-07-2004, 04:28 PM
