that sub comes prewired as 4 ohm, so just leave it in series and connect it at a 4 ohm load
should be good to go!
Here's what I have:
Infinity Reference 5761a 6-channel amplifier
JBL GTO Series 1002D Dual Coil Subwoofer
What's the best way to go?
1. Use the amp bridged into a 4-ohm load and
a. Connect the sub in parallel, or
b. Connect the sub in series
or
2. Use the amp in 2-ohm stereo and connect each coil as a seperate subwoofer
Thanks!
-Meta
Jan Bennett
Thanks! I did just that and it sounds great.Originally Posted by Red GTi VR6
Jan Bennett
