Well here you can see where the ground is attached. To the bolt holding the back seat down.
I thought the bolt, going thru a hole in the chassis, would carry the ground signal thru the chassis, to the bolt to my gold connection. And it DOES, because the amp is on, and works fine. Its the ground niose/engine whine thats the problem.
Does this connection look bad/good to anyone?
The amps wires might look "ugly" but they are a solid connection, usually that crap is hidden under the amps wings.
LinkBack URL
About LinkBacks
