Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Problem with New system... PLEASE HELP
    Nov 2005
    I just put a new system in my car (3 kicker L7's and a 2800 watt kicker amp.
    My problem is that the music that comes out of the computer doesnt use the system only cd's.
    Any advice?
    _
    Mar 2004
    Little Elm, Texas
    only cds...meaning only cds that are in your head unit? are you using a head unit?
    this is hardly enough information to work with
    do you know if you're getting sound out of the computer in the first place? (headphones to the jack on the mobo)
    Jan Bennett
    Nov 2005
    Ok so here's the deal...
    I got my carputer about 3 months ago. So far , so good. Everything has worked fine and I havent had any problems. I just recently bought a new stereo system (3 subs and an amp). All of which is hooked up to a panasonic cd player (PC through the aux input)
    Problem....
    I just came back from getting everything installed, sounds unreal, but only on cd mode. The sound that comes out of the computer only uses the door speakers. NO SUBS!!!... I just spent about $5000.00 on a competition stero and dont even own more than 5 cd's.
    Is there another way to hook the sound from the computer to the deck???
    _
    Mar 2004
    Little Elm, Texas
    what mobo?
    have you read through this thread?
    VIA MII 1000 5.1 Sub out
    not sure if it's the same problem you're having or not though
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    and btw - why did you start two threads on the exact same topic?
    Jan Bennett
    Nov 2005
    Just wanted to make sure everyone knew what I was talking about and I wasnt sure how to delete the old one.
    May 2005
    Derbyshire, UK
    Two threads ?? Make that four....
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
    _
    Mar 2004
    Little Elm, Texas
    wtf?
    now it's 4?
    dood, someone needs to sit down and have a long talk with you...
    as for deleting, you can't be serious can you? you must not have even looked or tried!
    Jan Bennett
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Just have somebody that knows a lot about computers (a nerd...lol) sit down in your car and check your sound settings in windows. 100 bucks says that it is either a software issue involving your soundcard or a windows issue involving the sound settings in control panel (enabling the sub out and turning up the sub volume)....another thing that you might want to remember is that your cd might be putting out a higher voltage signal and this will contribute to it being louder.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Nov 2005
    its not even that its just louder.... The subs wont work AT ALL when the sound is comming from the computer.
    but they pump when its comming from the cd player
  1. FS: VIA M9000 System
    By fromplanetbob in forum Classified Archive
    Last Post: 06-01-2005, 07:03 PM
  2. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-16-2004, 11:38 PM
  3. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
  4. Lilliput LCD, 2000 Celica GT and voltage problem
    By Goose in forum LCD/Display
    Last Post: 12-29-2003, 04:53 PM
  5. Do I have HU or not? -- Factory Audio system
    By helloman in forum General Hardware Discussion
    Last Post: 03-06-2001, 03:11 AM
