Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Hardest hitting 6x9s?
    Oct 2005
    I have a Honda Accord Hybrid so I dont have many options for a Subwoofer due to the the isolation of the trunk.
    I would like to know what are the hardest hitting 6x9's out there. I have a Rockferd amp that will be pushing them.
    Falls Church, VA
    Really arent any. Have you thought about a couple 8"s? Maybe under the front seats or facing towards the rear?
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    I'm in the process of modifing my 6x9 speaker holes for 6.5" speakers, I've been testing out and listening to differnt speakers, and buy far, 6.5" completly own 6x9s
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    just how isolated is the trunk?
    carputer - done.
    Constant Bitrate TyBong's Avatar
    May 2005
    Rhinelander, Wi
    (instert dave chapelle's voice here) THOSE 6x9'S POUND *****ES! anyway, what are the specs of the amp? how much $$ do you want to spend in this setup?
    MORE COWBELL.
    Oct 2005
    Between the trunk and the back seats there is some kind of wall consisted of thick foam, metal square boxes for the hybridism, and more thick foam.
    I knew putting a sub box in the trunk wouldn't sound as good as if it was the average typical trunk but I went ahead and tried it out. In the cabin I could barely tell that there was a sub back there. So, at this time, I have the 12 inch sub and box sitting on one of the back seats. GEHTO!
    _
    Mar 2004
    Little Elm, Texas
    What is a Rockferd?
    do a 6-pak of by-nines!
    it'll be crunk yo!
    *shakes head*
    there are always better options, always
    just because THAT sub /amp / enclosure combo didn't work, doesn't mean that using a sub back there isn't the best option.
    describe your set-up that you had back there that's now in the back seat?
    Jan Bennett
    Mar 2005
    NYC
    I don't think you'd have a problem since bass travels.
    or go with 4 12's.
    May 2005
    earthquake makes a line called the SWS subwoofers so thay should fit damn near anywhere.. maybe even in the door?? or under you seat and aura sound makes a bass shaker to simulate the low end (but i found it did work vary well for my application)
    Mar 2006
    Boca Raton, FL
    I have a pair of Kicker 6x9's (KS693) and they pound! They do 35-40 Hz with decent volume and handle the tough 75-175 Hz range with no problems at very high volumes. 6x9's have nearly as much surface area as an 8" sub, so these might be enough for you, especially in a smaller car.
  1. Mounting 6x9's
    By CavityCr33p in forum Car Audio
    Last Post: 02-24-2006, 10:43 AM
  2. Need 6x9's, want to trade!
    By CavityCr33p in forum Classified Archive
    Last Post: 08-01-2005, 10:45 AM
  3. Testing system before hitting the car
    By CavityCr33p in forum Newbie
    Last Post: 04-14-2005, 05:55 PM
  4. FS/FT: Infinity Kappa 6x9's and Alpine 6.5's
    By earndog in forum Classified Archive
    Last Post: 03-24-2005, 04:35 PM
  5. Issues with 6x9's :(
    By hcker2000 in forum Car Audio
    Last Post: 02-26-2005, 12:12 AM
