Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: pc to amp
    Newbie paradoxni's Avatar
    Jun 2004
    Antrim, Northern Ireland
    pc to amp
    In my previous car the PC was connected to aux-in on the HU and then the HU outputting to the amp. Im just wondering the effect on removing the HU completely so I have PC --> amp. I will use my carnetix controller to remote turn on the amp after ignition. Will I notice lower volume/quality? What will be the effects of this?
    Thanks,
    Newbie specsix's Avatar
    Aug 2002
    Sedro Woolley, WA
    It depends if your HU sent a passive signal or not. If it was doing some sort of pre-processing, you could lose some gain. I cannot see you losing quality. If anything, you would gain quality because you are simplifying your system by direct connecting your PC to the amp.
    BUT! Make sure you use some sort of frequency cross over. Dont just send your entire signal from your PC to AMP unless you dont care about seperability.
    I use an Audio Control HPX which takes in the PCs signal and then crosses over to the respective amps hi and low.
    Low Bitrate tasteItheIvalue's Avatar
    Nov 2005
    Connecicut; United States
    sorry to give a re-birth to this thread but... the pc lacks line voltage, so you will lose the ability to play your music loud w/ no distortion. might want to look into line drivers if your going from pc to amp. www.audiocontrol.com (check out the thee.1)
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by specsix
    this is absolutely positively NOT true and is providing the OP with inaccurate information.
    the outputs from onboard sound have very little voltage (something like a half a volt). Because of this, your noise floor will be very low and will allow noise to be introduced into the system VERY easily. And as the person above me stated, you will loose the ability to turn the volume up and not distort. Your music will sound like hammered dog ****.
    Jan Bennett
    Nov 2005
    Quote Originally Posted by Red GTi VR6
    about the hammered dog ****
    Mar 2005
    NY
    i have a dog...one day i'll get my little brother to hammer his 'presents' to find out how that sounds. I just hope it sounds better than what i'm currently dealing with in my revived celica. But seriously, get the line driver. THe guy who linked you to audiocontrol was smart. Get a crossover from there, if you need it, instead because it also has a line driver built in.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Nov 2005
    wow, too bad for this guy that we didnt post here back in march. until yesterday he had some horrible advice...
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Genesisfactor
    PLEASE let me know, I'm really interested to know how it sounds!
    Jan Bennett
    Mar 2005
    NY
    but you seemed to be the knowledgable one!!! Gah....there goes all the fun of doing it...
    Wait, wet poop or dry poop?
    (we see to do this in every thread lately, i swear)
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Aug 2002
    Sedro Woolley, WA
    Yeah I apologize for not being more clear. I specifically told him not to connect his amp to his PC unless he didn't care about seperability. I should of added low signal.
    I also mentioned the audio control hpx. I didn't type that out to exercise my fingers :P
    Also not all sound cards send low voltage. I just checked before I responded. My MAUDIO card outputs 4.99 volts on the rcas. I know this card is rare, but its simply not true to say all cards have low voltage.
    Again I am sorry for misleading you.
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  3. Car PC & Bose/Philips CCR800 Aux input
    By Gamer64 in forum Car Audio
    Last Post: 01-25-2007, 04:13 PM
  4. A heatsink case for small PC (like a power amp style)
    By phoTToniq in forum General Hardware Discussion
    Last Post: 08-27-2003, 11:15 AM
