Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: HDD&Engine noise, only with the carpc
  1. #31
    Jun 2005
    There were many M10000's sold that had bad grounds at the audio jacks on the motherboard. If you can hear hard drive and mouse movement noise, then that is the problem. Out of all the boards that EPIA offers, the M10000's are the very worst for build quality. The MII's are a better investment.
  2. #32
    Nov 2005
    I've got the M13000, could that also have the bad grounds for the audio? How would I go about checking that with a MM, and how would I fix it if it does turn up to be bad grounds there.
  3. #33
    _
    Mar 2004
    Little Elm, Texas
    Mechanic - that's good to know!
    Do you have a link to anything by Via confirming this?
    I'd love to read up about it!
    Jan Bennett
  4. #34
    Jun 2005
    ascendotuum : I am not sure that this issue would even be associated with any EPIA board other than the M10000. If you hear mouse movement noise then perhaps it would be the same issue. Not sure what the fix would be. We evaluated a few M10000's for use in our own products, found out what crap they really were, and sent them back.
    Red GTi VR6 : EPIA would not even admit to the bad batch of capacitors they used in thousands of M10000 boards until the issue was made public through other investigations, so I really doubt they would even acknowledge that there is an issue with their motherboard sound jacks.
  5. #35
    Low Bitrate 2000Jeep's Avatar
    Mar 2006
    hey cris,
    im having the same issues as you are. I was wondering if you found the problem?
  6. #36
    Mar 2006
    nevermind, i believe i fixed mine, i took the ground from the main HU and grounded it to the PC. Seems to work so far. ill let you know after i rerun the wires for the final time.
  7. #37
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by 2000Jeep
    Good to hear that 2000Jeep, 'cause I didn't solve my problem. Please let me know!
  8. #38
    FLAC sama's Avatar
    Feb 2006
    London, UK
    voltage cleaner didnt' help cris?
  9. #39
    Mar 2006
    I can hear a little and i mean a little of the hd, but not bad at all.
  10. #40
    Romania
    Quote Originally Posted by Mechanic
    Interesting to hear that, but in my case, I don't think it's the audio jack, as when powered by a regular PSU, I can't hear any noise. This leaves me to think it's the Opus causing the noise...
    Quote Originally Posted by sama
    Haven't tried it yet. I'm going to make one shortly.
    I know what you mean...with the music on, it's not noticeable, but when silence I can hear it. Not that annoying since I stayed 2 years with it, but it shouldn't be there...
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. 100% noise free carpc setup?
    By jeffmat in forum Car Audio
    Last Post: 02-06-2006, 06:43 AM
  3. Got rid of BUZZ noise!!
    By bleunetizen in forum General Hardware Discussion
    Last Post: 10-30-2005, 08:20 PM
  4. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  5. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 02:33 PM
