Results 11 to 20 of 22
Thread: Why do I have low volume???
  1. #11
    Dec 2005
    San Jose, Ca
    haha I think I was typing out my last reply when Red posted :P
  2. #12
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Instead of setting your amp gain digitally to 4V.....try setting it to 1V or less than 1V if possible and report back.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    have you set your gains on your amps correctly?
    Jan Bennett
  4. #14
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by PhatMo
    Thanks for all the input guys..
    The SB X-Fi puts out 2V RMS and the wave volume controls are all up. Centrafuse, which is the front end that I am using, does have direct control of the master volume. Is this what you mean by having my front end "map" with the master controls? I am not able to set the gains on my amp (Alpine MRV-F345), all I can do is digitally specify the input voltage. I have it set at 2V and I have tried putting it at 4V to see if it makes a difference, but it doesn't.
    I have this problem with any audio I play on the computer, including videos, MP3s, and Cds. I have to turn the master volume up half way just to hear the music when im driving. Then I have to go to 90% to get the volume to a normal listening level. I am running the amp to stock speakers in the car...do you think there is a problem there? I have a Lexus and I hear that Toyota/Lexus speakers dont mix well with aftermarket amps.
    I'm not sure how much a line driver would really help me because I already put out 2V RMS from the sound card. Any other thoughts on this?
    I can't find the thread that people stated line drivers do not make a difference in volume but I will keep looking. They probably had cards that already put out 1-2V.
    I don't see how it couldn't make a difference. That's what they do, increase the signal (voltage)
    I can tell you for my setup (stock infinity amp with no adjustments) works great.
    BTW, it bumps mine up to about 4.2v
  5. #15
    Dec 2005
    San Jose, Ca
    Hmmm maybe a line driver is something for me to look into then.
    I will try putting my input voltage setting at 1V and I will tell you what happens when I get out of class (lecture got boring so I decided to check the forum). Maybe the amp will amplify the output more because it thinks the input voltage is lower. Good idea 3ondubs.
    Red, I dont have any direct control over my amp gains. All I can do is specify the input voltage from the source. Its cool but it sucks at the same time.
    Shotgunefx, are you saying that you noticed a difference in loudness and clarity with the line driver?? Are you using integrated or a card from your computer??
    Keep the ideas coming guys!
  6. #16
    Apr 2005
    Boston, MA
    ...Shotgunefx, are you saying that you noticed a difference in loudness and clarity with the line driver?? Are you using integrated or a card from your computer??
    I've used it with the lineout on my Sirius my headphone jack on my laptop (problems with the driver in linux enabling lineout ) and the headphone jacks on various portable mp3 players.
    My amp doesn't have any adjustable gain. My HU put out around 5v so putting in 2v or under obviously made for low volume. Without the linedriver, I'd say on a scale of 1-10, I could get 2~3. With the linedriver 7-8. For my setup, it's a gaint improvment.
    You're results may vary.
  7. #17
    Dec 2005
    San Jose, Ca
    Well everyone that did it. I just turned the input voltage to 1V and the sound went up a lot! The problem is now my bass isn't loud enough because it is drowned out by the highs. I probably shouldn't turn the gains up on that amp any higher though, they are already half way. Maybe I will just get a line driver for the subs.
    The one thing I realized is that my bass in Centrafuse 1.6 is lower than winamp and windows media player. The bass in 1.5 was very loud, but for some reason, 1.6 isn't. If I play a song in winamp I have plenty of bass. Anyone else realize this or is something else messed up on my end :P
  8. #18
    _
    Mar 2004
    Little Elm, Texas
    TUNE!
    http://www.350z-tech.com/zwiki/Tutor...plifier_Tuning
    otherwise, you're waisting your time.
    Jan Bennett
  9. #19
    Aug 2005
    Anaheim Hills, Ca
    I knew that work for you...just make sure that there's no distortion or you've turned it up too high. You should do the same for the sub amp as the sub input voltage is also low.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  10. #20
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by Red GTi VR6
    TUNE!
    This was a really useful link to me - thanks! I'd been looking for some instructions like this.
  1. Pionner IP_Bus HACK low volume.
    By Jcarere in forum Car Audio
    Last Post: 11-05-2005, 01:44 PM
  2. Pioneer IP-Bus input has low volume
    By ashtonaut in forum Newbie
    Last Post: 08-28-2005, 04:37 PM
  3. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 09:49 PM
  4. Low volume coming from speakers.
    By nappyjim in forum General MP3Car Discussion
    Last Post: 10-12-2004, 08:19 PM
  5. Ext Apps Volume too low
    By goof in forum Media Engine
    Last Post: 05-09-2004, 06:21 AM
