Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Why do I have low volume???
    Dec 2005
    San Jose, Ca
    I installed my carputer a few months ago and I WAS very happy with the sound. I have a soundblaster X-fi sound card and the clarity is amazing. But recently I realized that the volume doesn't get as loud as I would like it to, even when at 100%. I have to listen to music at 90% just for me to hear the music at a moderate level. Its just not as loud as other systems that I have seen. There are just some times when I feel like listening to music loud and my system setup right now doesn't allow me to do that. Even my stock system was way louder than this while still sounding clean.
    I realized this volume issue when I sat in my friend's car who has an alpine deck (which I do not...I run from the sound card directly to the amps) running to a couple of alpine amps, CDT speakers and no computer setup. His system gets very loud and you can judge how clean it sounds by the hardware...its amazing :P.
    I've done some research and from what I hear getting a line driver does nothing to solve volume issues. Anybody have the same experiences? Any suggestions??
    _
    Mar 2004
    Little Elm, Texas
    have you checked the sound on windows?
    have you checked the sound in whatever program you're using to play your music?
    have you checked your gains on your amps? (better yet, have you set them properly?)
    are you sure that this isn't just your recording?
    do CDs play any louder?
    if you're reading that a line driver does nothing, I'd like to see that thread please! Post up a link if you can.
    If you're not getting your amps the voltage they need, then they can't produce the volume in the first place. This is where many people rely on the adjustable gains. They are there for this reason, but many times, people abuse them.
    If you don't have anything to work with in the first place, then turning up nothing won't give you much of anything....make sense?
    btw - I know that on the M10000, the voltage out from the mobo on-board sound is only like .5v....that's hardly anything
    do you know what the voltage out on the X-FI card is?
    Jan Bennett
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    This is a common problem when not using a headunit - the typical suggestion is to use a line driver or use the aux-in on a headunit.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    have you made sure that both your WAVE and MASTER volumes are set at a appropriate level?? (I assume you are experiencing the volume issues when playing a MP3 ...
    Falls Church, VA
    Your wave or master volume level is low. The xfi has PLENTY of output voltage. no line driver required.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Line-driver worked for me. I used a Pac turbo-1. Could be a bit louder, but 100 times better than without. Then again, at the moment I'm using a headphone jack. Not sure what the difference in voltage between that and a line-out are.
    Lineout may or may not be louder.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Set the gains on your amps properly (tern em up a bit)....and make sure that your front end maps your music volume to general volume.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Apr 2005
    Boston, MA
    Quote Originally Posted by 3onDubs
    If you have them. My factory amp has no controls.
    _
    Mar 2004
    Little Elm, Texas
    how about we let the guy come back in here and respond to the given things first....lol
    Jan Bennett
    Dec 2005
    San Jose, Ca
    Thanks for all the input guys..
    The SB X-Fi puts out 2V RMS and the wave volume controls are all up. Centrafuse, which is the front end that I am using, does have direct control of the master volume. Is this what you mean by having my front end "map" with the master controls? I am not able to set the gains on my amp (Alpine MRV-F345), all I can do is digitally specify the input voltage. I have it set at 2V and I have tried putting it at 4V to see if it makes a difference, but it doesn't.
    I have this problem with any audio I play on the computer, including videos, MP3s, and Cds. I have to turn the master volume up half way just to hear the music when im driving. Then I have to go to 90% to get the volume to a normal listening level. I am running the amp to stock speakers in the car...do you think there is a problem there? I have a Lexus and I hear that Toyota/Lexus speakers dont mix well with aftermarket amps.
    I'm not sure how much a line driver would really help me because I already put out 2V RMS from the sound card. Any other thoughts on this?
    I can't find the thread that people stated line drivers do not make a difference in volume but I will keep looking. They probably had cards that already put out 1-2V.
  1. Pionner IP_Bus HACK low volume.
    By Jcarere in forum Car Audio
    Last Post: 11-05-2005, 01:44 PM
  2. Pioneer IP-Bus input has low volume
    By ashtonaut in forum Newbie
    Last Post: 08-28-2005, 04:37 PM
  3. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 09:49 PM
  4. Low volume coming from speakers.
    By nappyjim in forum General MP3Car Discussion
    Last Post: 10-12-2004, 08:19 PM
  5. Ext Apps Volume too low
    By goof in forum Media Engine
    Last Post: 05-09-2004, 06:21 AM
