Results 1 to 10 of 16
Thread: Is there a way to make a deck hold power on startup?
    Constant Bitrate rotarypower101's Avatar
    Oct 2004
    Portland/MtHood Oregon
    Is there a way to make a standard aftermarket car deck not turn off and back on “as if power was cut from the ignition line” at startup?
    I am sure there is something out there like this I just need to know what it would be called and what the process/components are.
    Would a cap work for something like this?
    Is there a thread someone could lead me to that talks about such a thing?
    Mar 2006
    correct me if im wrong, but couldn't you just put a constant power to the remote wire on the back of the deck and just put a swith on it to turn it on and off yourself?
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    yes what you want to do is hook up 12v constant power(yellow) to the Accessory wire(red one). Make sure you turn off your deck or your battery will die.
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
    Oct 2004
    I still want it to operate in the standard way for the ignition to turn the unit on and off, but….say if you have the stereo running with the car off (acc on) and click the key over to start, the stereo would not cycle off and then back on.
    I know some ignitions do not allow this as they sweep past off position from acc and then into engine crank position, but I think foreign cars (at least the ones I know of) like mine do not, and sweep from off to acc to start.
    I am fairly sure this is possible, and that the problem is the drain on the system at crank, draws enough current to turn the stereo off as if power were cut.
    I have mistakenly half turned over the engine and then while the engine was still in a expansion stroke but not started yet turn the key and start the engine, and this did not stop the stereo from continuing to play as it usually does at crank.
    I am right to assume most if not all cars work in this way correct, where at crank if you are listening to a cd the player stops and comes back online after essentially restarting from off position?
    I know my electrical system is sufficient, as I am using a newer red top optima battery with plenty excess CCA and the stereo is stock except for the HU.
    Am I making this clear enough to relay what I am asking?
    I just don’t want the stereo to shut off while changing the key position from acc to starting position while the engine cranks.
    Apr 2005
    San Jose, CA
    Oh ok, yea a capacitor would work, but it would have to be a big one. You should probably go with some kind of delay circuit. Maybe something like this http://www.electronickits.com/kit/co...lec/ck1614.pdf
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by rotarypower101
    There is another way. What you need to do is get your voltmeter out, and check each fuse in your fuse box. Some switched fuses remain on when you start the car, and some don't. Just run a wire from the fuse that remains on to your radios acc wire, and you should be good to go.
    Michael
    Jul 2005
    SD, CA
    Best route is what has been previously discussed. Connect the acc wire from the deck to the battery line then either be sure to turn the deck off. If you are worried about battery draining then get a switch.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by ArcticGenes
    best route? i think wiredwrx has the best route, it doesnt involve human interaction.
    another thing would be to setup a relay and delay. when the acc line hits 0volts the relay would switch to constant power for a few seconds. if the acc line doest get power in few seconds then the stereo would shut off automatically.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2004
    Quote Originally Posted by Wiredwrx
    Michael
    Beautiful and simple!
    You really are a Jack of all trades around here aren’t you!
    Thanks for taking the time to help us inexperienced guys.
    Are there some unforeseen reasons why these are wired like this from the factory?
    I will see if I can’t make this work for me.
    Any advice as to which circuit would be best to tap into?
    I should probably go with the highest rated circuit in the fuse box right?
    I am taking a guess the highest rated one would have the least effect on exsisting systems right?
    Fusion Brain Creator
    Mar 2005
    to give the starter the maximum output from the battery.
    some stuff, like the engine computer, must stay on through cranking.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Laptop Startup Solution - Opinion
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-20-2004, 05:33 AM
  3. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
  4. How to make it power down when ignition off?
    By domdino in forum Power Supplies
    Last Post: 10-07-2002, 09:26 AM
  5. How do i make -8V from 12V power?
    By helloman in forum Power Supplies
    Last Post: 04-26-2001, 01:33 PM
