Is there an onstar box or anything else in your trunk which might give off RF?
Yesterday I finally had the time to place my case there where I wanted (in the trunk)
Last 3 weeks I was driving with the PC case on the passangers floor.
Unitl yesterday every was running well. Sound was good without any problem.
But now I have a really strange problem.
I use a 4.1 PCI soundcard. The front speakers are connected to the front-out, and the back speakers to the rear-out put.
If I connect the jack in the rearout-put I hear a very strange noise when the music is off.
When the front jack is connected to thr front-output the sound is not here.
Because I wanted to be shure the the problem came from the cables (maybe running to close to the power cables, I connected the front jack in to the rear out-put. Noise then came back![]()
If I connect the rear jack in to the front out-put noise is gone.
So what I think is that the rear out-put conector is the problem.
Because If it was one of the cables I would have this noise also when I connected the jack in the front-output.
So this is the problem:
frontjack in front out-put , no problem
front jack in rear out-put, NOISE
rear jack in front out-put, no problem
rear jack in rear out-put , NOISE
What could cause this NOISE.
Case Is grounded through the M1-ATX powersupply. This one is connected to the ground of the car.
Like I said, befaore I moved the case the problem wasn't there
Gods right foot!!
Renault Grand Espace 3.5 V6
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
In the back there is nothing close to the PC.
Gods right foot!!
I don't think its the connector. The only thing that changed was you moved where the PC was located. That means, I assume, you rerouted the wires when you moved the PC. Do you get the noise both when the engine is running AND when the engine is turned off?
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Yes, Both. Doesn't matter if the engines is on or off
Gods right foot!!
What is the brand and model number of the sound card?
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
I'm assuiming you kept the powerline and signal lines serate, right?
Could it be the ground of one of your cables is fubar'd?
Are you sure you are using the output jack and not a line-in?
Originally Posted by JC-S60
I was thinking the same thing about the wrong jack. Thats why I asked what model sound card he had...
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Soundcard is a Sweex 4.1 . I use the black out-put as REAR one, and green as FRONT.
Cables are running next to each other.
If thats a problem why does the NOISE not come up when I connect the FRONT output only.
Thats why I want to find out if the proble lies somewhere else
Gods right foot!!
